355 build up ?
Old May 5, 2005 | 10:37 PM
  #46
marshall93z's Avatar
Re: 355 build up ?
And what about a SP on a heads/cam car? I'd like to see the differences ONLY the intake made. But I'm sure the cam specs would be thrown out the window.
Old May 5, 2005 | 11:11 PM
  #47
SStrokerAce's Avatar
Re: 355 build up ?
Originally Posted by marshall93z
I always thought it used a round TB, like the LS1?
Not if you have a good elbow.... working on that now.
Damn....1000 bux?!?! Didn't those things flow within "less than 10cfm's" ofthe CNC ported ones?
Yeah but they could go 345-350 if done right...
Originally Posted by me
396 cubes: H Beams, Dragonslayer Crank, Custom Pistons
Race preped block: bushed lifter bores, 4 bolt conversion etc...
TFS Heads: Stage 3 Meaux Porting, Hollow Stem Valves
Super Vic Single Plane: Ported to match heads
Hyd Roller Valvetrain: all the good stuff ;-)
What do you expect this one to make?
The customers goal is 450rwhp, daily driveable and then he added "beat a new ZO6"
My goal 650hp STD on the engine dyno, 620 SAE... Over 500rwhp and idle at 750-850rpm That should keep up with a ZO6 in a 3600lbs car...
Ii'm siked about the crate motors too.... just have to work out the details on them here soon but other projects await.
Bret
Old May 5, 2005 | 11:12 PM
  #48
Re: 355 build up ?
Jon A was going to do that but his short block gave out.
I'm going to send a SP to a customer with a 383 to test out so it should be good to see what a 425rwhp 383 gains with it.
Bret
Old May 6, 2005 | 04:21 AM
  #49
Jon A's Avatar
Re: 355 build up ?
And dammit anyway. That would have been so much fun.
Old May 6, 2005 | 09:52 AM
  #50
Re: 355 build up ?
Bret
Will definitely be interesting to see!
Old May 6, 2005 | 11:24 AM
  #51
95Bird's Avatar
Re: 355 build up ?
I'm choompin at the bit to see what it could do on my car. I guess I just need to do it..unless someone has one I can try out. I will do a back to back dyno test and share all results.
Old May 6, 2005 | 02:12 PM
  #52
Re: 355 build up ?
Add in gaskets, studs, fasteners, oil pans, pickups, OIL PUMPS, timing covers, nick knacks
Bret
Is the stock oil pump not good enough?
Old May 6, 2005 | 02:18 PM
  #53
Re: 355 build up ?
no stock oil pump that is checked over/blueprinted is great
Old May 6, 2005 | 02:27 PM
  #54
Re: 355 build up ?
Are you saying no?? I dont understand...
Old May 6, 2005 | 02:42 PM
  #55
Re: 355 build up ?
lol how do i say it then...
A stock blueprinted oil pump is PERFECT for a buildup.
I didn't mean for the oil pump to be plural.... you can only get one in there!
Old May 6, 2005 | 03:31 PM
  #56
Re: 355 build up ?
lol...Yeah, I know you can only get one in there! I was just confused about the way "no" was used. Seems like it needed a comma in there or something?? I read it is "no stock oil pump is great". See what I'm saying?
"no stock oil pump that is checked over/blueprinted is great"
Old May 6, 2005 | 06:01 PM
  #57
Re: 355 build up ?
yeah I gotta busted paw here so writing correctly is not numero uno now
Old May 6, 2005 | 06:28 PM
  #58
Re: 355 build up ?
No problemo, I was just curious what you really meant.
Old May 6, 2005 | 07:30 PM
  #59
Re: 355 build up ?
There should be a good thread tonight about a 355 build up ;-) ... look for it!
Old May 6, 2005 | 09:06 PM
  #60
Re: 355 build up ?
I will...
