*excellent info* 93 specific info list.
<font face="Verdana, Arial" size="2">Originally posted by old93z:
No "air bag" written on pass. side because i believe there is not a pass. air bag. They put those in on 94 and up.
</font>
</font>
I beg to differ! My RPO options clearly show an AK5 listing and that is decoded to : RESTRAINT SYSTEM FRONT SEAT, INFLATABLE, DRIVER AND PASSENGER.
1993 Z28 A4
K&N air filter
Mod suggestions accepted
My 93' does say AIR BAG on the passenger side dash. Am i the only one
1993 Z28 A4
13.3@103mph
LPE CAI, gutted cat, exhaust cut out
Waiting to be insalled: Yank 2800 TC, TransGo shift kit, B&M tranny cooler
1993 Z28 A4
13.3@103mph
<font face="Verdana, Arial" size="2">Originally posted by Dragon Racing:
</font>
?</font>
And I'm not sure if anyone mentioned this(didn't read all 4 pages), but my 93 does not have the stretchy strap on the visor to hold stuff.
93 Z28 Red/Blktp A4 3.23
Mods: 17x9.5 and 17x11 Fikse FM/5s, Borla, PB Coated Mac Headers/Y-pipe, Offroad pipe, MTI CAI, TB!, 8mm, Eibach Sportlines, KYB struts/shocks, BMR Adj. Panhard
"Work Harder! Millions of people on welfare depend on you!"
Bralgar, he was saying that it just didn't say "airbiag" on the dash. They have airbags for the front people. Dragon, I guess you are the only one. My late 93 six clyinder does not say it. MAybe yours were deployed at some point and they just bought some used ones from somebody off of a message board.
My junkie car will
NOT break 88 MPH in the eighth.
Anyone want to sell me
some good 4.10's?
My junkie car will
some good 4.10's?
Seriously, mine does say AIRBAG on the passenger side dash. That is weird that nobody else's does. I have a friend that has a 93' also....i'll have to check his out to see if his says it or not.
Also, no stretchy stuff on the visors for me also!
1993 Z28 A4
13.3@103mph
1993 Z28 A4
13.3@103mph
<font face="Verdana, Arial" size="2">Originally posted by whitehooptie:
</font>
</font>
<font face="Verdana, Arial" size="2"> Originally posted by old93z:
I believe there is not a pass. air bag. They put those in on 94 and up.</font>
1993 Z28 A4
K&N air filter
<font face="Verdana, Arial" size="2">Originally posted by Sixer-Bird:
93 LT1's used multi-port fuel injection(MPI). All other LT1's have sequential fuel injection(SFI) like they are supposed to.
</font>
</font>
Probably the same principle between the two.Dragon- You should've mentioned on the other board that you wanted to know about 93 CAMARO's rather than Pontiac's as well.
Another thing I found out... I talked to several people who said 15" rims would not fit on the rear but they do. I don't think they do on later models but my 15" rims and ET streets had nearly 3/4 of an inch clearance between the rim and the caliper.
93 Trans Am a4, g2 intake w/k&n filter, holley 52mm tb, fan switches, bbk headers, no cat, flowmaster cat back, 125 shot w/compucar wet plate, zz9 cam, angle valve job on heads, ET Streets for the track! Best ET w/potenza tires, 100 shot, and hypertech chip..
60' 1.763
12.112 @ 113.16
60' 1.763
12.112 @ 113.16
So did we ever find out if:
The spring seats/pockets are a different size than the 94-97 cars?
The 93s have hardened pushrods? (for use with guideplates)
EDIT: Looks like that's a yes on the hardened pushrods http://web.camaross.com/bb/Forum1/HTML/106091.html
Red 1993 Z28
[This message has been edited by QUICK305 (edited July 24, 2002).]
Red 1993 Z28
I just read through my service manual and my t.a. has dual airbags. It says SIR on the dash and steering wheel. Remote keyless entry was an option also for pontiacs. When did camaros start getting radio controls on the steering wheel? My t.a. has those also.
93 T.A. m6
bolt-ons and 125 shot
93 T.A. m6
Updated again.....finally!
My Valentines gift '01- Red 93 Z28 M6-
Rhino clutch, Flowmaster 3" cat back, K&N FIPK w/ S&B filter, intake baffle capped, Throttle body Airfoil, RK Sport Air Dam and Rear Spoiler, LS1 3" aluminum DS, BMR STB, LS1 brakes, T.O. SLP shocks and springs, ADS stage 2 chip, 160 t-stat, !TB, !heat extractors, manual fan switch,
!Radio option thanks to some punk!
Best time 14.454 @100.42
beware of needle bearing input shaft bushings
<font face="Verdana, Arial" size="2">Originally posted by chevroletfreak:
Mechanical
</font>
Mechanical
- Oil pressure sender is directly above the oil filter instead of on the back of the intake manifold (unconfirmed)
</font>
-Erik
1995 Silver Trans Am
- 6 Speed
- K&N FIPK
- Borla CatBack
- !TB Bypass
- 160 Stat
- Pro 5.0 Shifter
