*excellent info* 93 specific info list.
Old Feb 21, 2002 | 04:22 PM
  #16
PaulDobesh's Avatar
Post
Yup- Leather is available in the 93 Formulas, I have it. It's rare- but its out there...
Great list of differences. I'd love to know if adjusting fuel pressure would help performance...
93 Formula A4 w/3:23, Dark Green Metallic, Tan Leather- loaded with 55k miles.
SLP Bilsteins, Chassis Engineering SFC, Lingenfelter Cold-Air, Borla Y, Hypertech chip & 160 stat, TB foil, MSD Blaster coil, 17 in. ZR1 style rims, BFG Comp TA Zr's, Zaino.
Stereo- Xtant amp, Boston Acoustics composites, JL Audio stealth box, Kenwood head.
Old Feb 21, 2002 | 04:47 PM
  #17
BLUETOPTA's Avatar
Post
My car has the stretchy stuff on the sun visors.-Cool list though!
BLUETOPTA
1995 Trans Am covnvert. White w/white leater + blue top and accents BEST 1/4 et:13.7
in process of port & polish of intake & heads + other stuff
-1994 Cadillac Deville 4.9L
Old Feb 21, 2002 | 04:53 PM
  #18
93m6's Avatar
Post
I've got leather in my t.a. and an afpr set at 39.
93 T.A. m6
flowmaster,hurst,hypertech powerchip,air foil,afpr,fipk,3.73,msd6al,cutout,cat!,tb bypass,1.6rr,headers,traction bars,differential girdle,nw wet kit,msd ignition retard,window switch,wot switch,remote bottle opener,nitrous filter
formerly 93firechicken
Old Feb 21, 2002 | 04:57 PM
  #19
chevroletfreak's Avatar
Thumbs up
The list has been updated. Keep them coming!
My Valentines gift '01- Red 93 Z28 M6-
Trans roller pinion bearing, Rhino clutch, Flowmaster 3" cat back, K&N FIPK w/ S&B filter, intake baffle capped, Throttle body Airfoil, RK Sport Air Dam and Rear Spoiler, LS1 3" aluminum DS, !Radio option thanks to some punk!
Best time 14.454 @100.42
Awaiting install - LS1 brakes, slotted rotors all around and complete T.O. SLP shocks and springs
Old Feb 21, 2002 | 05:12 PM
  #20
flyn_lo's Avatar
Post
The FPR's aer located on the Passenger side on the 93 instead of on the Drivers side with the 94+. Such saying you have to buy a FPR For 93 only.
Old Feb 21, 2002 | 05:46 PM
  #21
DaytonaFBody's Avatar
Post
You forgot to mention a few things:
93 cars had a 4L60 transmission which is valve body and parts compatible with the 700R4 transmission. This adds a TV cable, making the throttlebody 93 specific. In addition, I've heard from some sources the 92-93 LT1 motor had different connecting rods than newer ones. What I've heard is it used GM pink rods rather than powdered metal rods. I've read on the list here that the valvespring seats are somehow different on 93's. Maybe smaller diameter?
Yes, 93 front brakes suck. I think the rear brakes are the same. I don't think traction control was available until 94 either.
Doug R - DB Speed Racing & Daytona F-Body Club -
Black 93 Z28 A4 -
Performance: Hooker LTs, 3500 stall,3.23 gears w/Torsen, intake port match, CAI, Hypertech, AFPR, UD pulleys
Suspension: Eibach Sportlines,1LE F/R swaybars, Adj PHR, LCAs and LCA brackets
Best time without 3500, with 3.73's: 13.11@106.7 (1.9 60')
Best time with 3500, 3.23 gears: 12.96@104.90 (1.81 60')
White 95 Z28 A4 - Almost sold. For Sale $6,500: 89k miles
Old Feb 21, 2002 | 08:19 PM
  #22
old93z's Avatar
Post
I believe the 93's had the 1.46 inch springs and the later years had 1.25 inch springs. Not positive but prety sure. Don't forget the 93's are faster.
Old Feb 21, 2002 | 08:26 PM
  #23
$hawn's Avatar
Post
I got two more differences that are not on that list that I thought of, 93's have the oil pressurer sending unit right above the oil filter, the other years are on the back of the intake manifold. Also the 93's alternator has a metal fan and the others have a plastic disc fan.
93 Z28 Patriot Red A4
Old Feb 21, 2002 | 08:41 PM
  #24
Bud M's Avatar
Post
No CAGS on '93 M6
Old Feb 21, 2002 | 09:51 PM
  #25
Thumbs up
Awesome info. Thanks everyone. I will update it as soon as i get a chance.
Old Feb 21, 2002 | 10:15 PM
  #26
oneqwkfbody's Avatar
Post
heres for the guy who wanted to set his fuel pressure regulator...take a reading of your stock regulator with your car running, then install your regulator and set the pressure at stock..or more. my car runs around 42-43.
also..they say the 93-95s had hardened pushrods...
i love my 93!
Brian
Bright Red 1993 Z28 A4
CFFB #03
Best 1/4 --12.539
Best mph 110.48
Best 60ft. 1.80
www.geocities.com/93z28lt1
Project 1979 Malibu Classic (Waiting to begin!!)
Old Feb 21, 2002 | 10:51 PM
  #27
kxgreenrider's Avatar
Question
i have a 93 camaro z28 with the generic mods,short shifter,exhaust,4:10 gear ,intake, i only have 17,000 miles on the car (all original) has any body had to rest the speedometer. i hvent installed the gear so i dont want to rck p ore mles then i need to..
Old Feb 25, 2002 | 07:33 AM
  #28
ZBLKHELLRZR's Avatar
Wink
Have to dispute the gear requiring the speedo box. You can have a speedo gear installed OR (controversial here) get the chip reprogrammed for the correct ratio.
Mine and a few others have done this instead and IT DOES WORK!
Old Feb 25, 2002 | 12:23 PM
  #29
QUICK305's Avatar
Thumbs up
Just wanted to say this is a great post, with lots of information. I think pretty much all the 93 specific info has been listed...Keep up the good work!
Old Feb 25, 2002 | 03:36 PM
  #30
Cameron B's Avatar
Thumbs up
Good info!
I would like to know more about the heated O2's for Long Tubes, since I plan on getting them soon. I too have noticed that my 93 is considerably quicker than other bolt-on LT-1's.
1993 Burgundy Trans Am - 134K miles, A4, 3.23, 245/50/16 Potenzas rear, Dunlop SP 5000 front, B&B Tri-Flo Twin Tip Exhaust, K&N FIPK, 160 Thermo, MGF Chip, ASP Crank Pulley, !TB Bypass, Taylors, NGK TR-55's, BMR STB, PHR, and SFC's, PIAA fog lights, Poly Tranny Mount, (biTch) Custom Reflective Decals, CSI H2O pump.
Best run to date: 5.0 0-60 / 13.63@105.6 1/4 via G-Tech
CameronUSC@yahoo.com
www.geocities.com/cameron93ta/index.html
