buy an ls1 or another lt1???
Originally posted by unvc92camarors
i'll give you an unbiased opinion, since i don't own a car with either engine...or a v8 at all for that matter
the ls1 will fall short of the lt1 thru the 1st 2 gears, but at 3rd, it is just all over for the lt1
l
l
theres no reason an LT1 will beat an LS1 through the first 2 gears if the LS1 driver knew what he was doin,unless it was an A4 vs. A4 or m6LT1 vs. A4 LS1. I think The A4 LT1 will get the jump at idle because most stock TC's stall around 1300rpm or so and the LS1 makes less than desireable power at that RPM (so does the F-Body LT1 but it still makes more at that rpm).
