TCS swap from another car?
Old Nov 10, 2005 | 08:06 AM
dhirocz's Avatar
I have a '94 Z and my buddy has a '95 t/a...mine has 3 channel abs, his has TCS. He doesn't want it. We're both going to pull our dashes out to put in new heater cores this weekend. Aside from the brake lines, axleshafts, backing plates and some of the wiring, is there anything else involved? I know the dash harness comes together under the driver's dash, will the tcs body harness join with my front harness and work correctly? Or is there more involved? I'm ready to swap harnesses and BCM's and everything, just wondering about the wiring compatability because he has the pop-up headlights and I dont so I want to make sure before tearing the cars apart that I dont need anything else.
Old Nov 10, 2005 | 08:49 AM
MustangEater82's Avatar
Re: TCS swap from another car?
also can anyone show me how a TCS wheel sensor is hooked up?
Old Nov 10, 2005 | 09:53 AM
The ABS units will need to be swapped.... one is 3-channel, the other is 4-channel. You will need to run another brake line to the rear brakes.... TCS has two, ABS has one. There is an interface to the PCM, so that will require reprogramming. Not sure if you might have to also swap the EBCM modules.
Moving to "General F-Body Tech & Info".
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
cmdeshon
Dec 12, 2014 10:51 PM
Ricardo
Nov 29, 2014 10:58 AM
USAirman93
Nov 24, 2014 03:37 PM
smokin5s
Jul 24, 2003 10:47 PM
