Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Custom plug wires
Old Jun 27, 2010 | 12:17 PM
klrz28's Avatar
Custom plug wires
Ok I get how to crimp the ends on to the plug wire. But how do you get the rubber boot to fit over and turn the 90?
Old Jun 27, 2010 | 02:57 PM
Put the boot on the wire first. Pull enough wire out the plug end of the boot so you can crimp the connector on the wire. Pull the connector/wire end into the boot gently, using the other end of the wire.
Old Jun 27, 2010 | 06:26 PM
rskrause's Avatar
Moderator
I just use a little silicone lube and it (the boot) slides right on.
Rich
Old Jun 27, 2010 | 11:44 PM
klrz28's Avatar
Sweet You guys ROCK!
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
GigaMp3z
Feb 20, 2003 02:57 PM
