Scan9495: Free OBD1 scan app for 93/94/95 LT1
Old Feb 27, 2017 | 04:29 PM
  #406
GaryDoug's Avatar
Prominent Member
Re: Scan9495: Free OBD1 scan app for 93/94/95 LT1
http://www.mediafire.com/file/f5nwyy...495_V2-5-1.zip
Old Jul 5, 2017 | 04:37 PM
  #407
bw_hunter's Avatar
Hi Gary,
I get the following message:
Scan9495.exe - .NET Framework Initialization Error
To run this application, you first must install one of the following versions of the .NET Framework:
v4.0.30319
Contact your application publisher for instructions about obtaining the appropriate version of the .NET Framework.
OK
I'm running windows 7 and using Mozilla Firefox. Can you direct me to the correct version of the framework?
Thanks,
Old Jul 5, 2017 | 05:21 PM
  #408
bw_hunter's Avatar
Never mind...I found it, All I had to do was open my eyes.
Originally Posted by bw_hunter
Hi Gary,
v4.0.30319
OK
Thanks,
Old Jul 11, 2017 | 02:39 PM
  #409
GaryDoug's Avatar
Prominent Member
Any version 4.0 or higher should be ok.
Old Apr 2, 2018 | 10:55 PM
  #410
Newby96's Avatar
Question Re: Scan9495: Free OBD1 scan app for 93/94/95 LT1
very good thread, I hate to beat a dead horse again, but im just gonna ask whats the most updated cable and program to download. getting a new laptop in the next week for tuning, and scanning. just making sure I get the right stuff. thanks again for all your guys help.
Old Apr 19, 2018 | 09:26 PM
  #411
krowtis's Avatar
Just downloaded on a new laptop with windows 10. Get an aldl cable tomorrow. Was able to open files and look through the software. Hopefully i remember to post an update when i use it. Until then, thanks for creating what looks to be an awesome scaning tool
Old Apr 20, 2018 | 06:46 AM
  #412
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
The software works great. I just wish I knew how to interpret all of the data.
Old Apr 20, 2018 | 08:39 AM
  #413
I have a 20+ page guide to interpreting the data, specifically for the LT1 engine. Was written about 20 years ago, when the LT1 ScanMaster was popular. I'll try and add a “sticky” to this forum, with a .pdf attachment of the guide. Used to have it on my website, but the source of the free server disappeared a few years ago, and website is gone.
In any case, if you have a specific problem you are trying to solve, or just want to see if everything is “normal”, you can post a link to the file and I will take a look at it.
Maybe it’s time to update my guide to match the output of Scan9495.
Old Apr 20, 2018 | 10:07 AM
  #414
BTC's Avatar
BTC
Thanks, Injuneer. The PDF might be a great idea.
I "think" I have a couple of issues, like a high idle. You and Gary both took a look at my logs and made some suggestions for things to check, do etc. My car isn't located in the state where I live, so I haven't had a chance to do anything to follow up. I should be able to check some stuff this summer when I'm back "home".
Old Apr 23, 2018 | 11:09 PM
  #415
krowtis's Avatar
Update to what i posted a few days ago. I just wanted to see if it worked. It did. I ran a scan, had zero codes which is no surprise. I have never seen the check engine light come on. Not bad for a 95 z28. Was loaded onto a laptop with windows 10.
Old Jul 28, 2018 | 06:43 PM
  #416
lmaley's Avatar
Gary
Thanks for all the information and software. I got the ALDL cable that was posted and used Win10 with no issues. I was able to see the codes that I needed to clear to move on with charging the AC. Thanks again
Old Jul 28, 2018 | 08:19 PM
  #417
GaryDoug's Avatar
Prominent Member
You are very welcome. Glad it worked for you so far.
Old Oct 29, 2018 | 02:50 AM
  #418
ridiqls's Avatar
Hey Gary,
Your software is great. Thanks for making it.
I wasn't able to find a guide on the ABS actuators and what they do, particularly if I want to activate the abs module to bleed it.
I see LF/RF Sol, Motor Apply, Motor Release, Rear and Home.
Can you provide some clarification?
Old Oct 29, 2018 | 08:41 PM
  #419
GaryDoug's Avatar
Prominent Member
I'm afraid I can't help much. I am a bit more of a computer geek than a car expert. The information for the actuators you mentioned came from a Tech II scanner. You might try downloading the service manual for the 94. It has a lot of info on the ABS system. I can tell you that I DID NOT include the brake bleeding routine in the app because it was rather complex and I did not feel comfortable generating it without full testing.
Old Oct 31, 2018 | 12:50 AM
  #420
ridiqls's Avatar
No worries, I'm glad you programmed it in anyway. So I found a few people mentioned it on facebook and decided to try it. If you click the "Home Motors" button in the Actuators, it will activate the abs block. When you home the motors, it makes a clicking noise that is audible from the abs unit.
I did that and bled the abs block out. I honestly don't know what exactly it means to home motors or if you need to do it more than once (which I did, just to be safe) but I was able to safely get the dirty brake fluid out of my abs module and it all worked out.
