Scan9495: Free OBD1 scan app for 93/94/95 LT1
#406
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Re: Scan9495: Free OBD1 scan app for 93/94/95 LT1
#407
Hi Gary,
I get the following message:
Scan9495.exe - .NET Framework Initialization Error
To run this application, you first must install one of the following versions of the .NET Framework:
v4.0.30319
Contact your application publisher for instructions about obtaining the appropriate version of the .NET Framework.
OK
I'm running windows 7 and using Mozilla Firefox. Can you direct me to the correct version of the framework?
Thanks,
v4.0.30319
OK
Thanks,
#408
Never mind...I found it, All I had to do was open my eyes.
Hi Gary,
v4.0.30319
OK
Thanks,
v4.0.30319
OK
Thanks,
#410
very good thread, I hate to beat a dead horse again, but im just gonna ask whats the most updated cable and program to download. getting a new laptop in the next week for tuning, and scanning. just making sure I get the right stuff. thanks again for all your guys help.
#411
Just downloaded on a new laptop with windows 10. Get an aldl cable tomorrow. Was able to open files and look through the software. Hopefully i remember to post an update when i use it. Until then, thanks for creating what looks to be an awesome scaning tool
#413
In any case, if you have a specific problem you are trying to solve, or just want to see if everything is “normal”, you can post a link to the file and I will take a look at it.
Maybe it’s time to update my guide to match the output of Scan9495.
#414
Location: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Thanks, Injuneer. The PDF might be a great idea.
I "think" I have a couple of issues, like a high idle. You and Gary both took a look at my logs and made some suggestions for things to check, do etc. My car isn't located in the state where I live, so I haven't had a chance to do anything to follow up. I should be able to check some stuff this summer when I'm back "home".
#415
Update to what i posted a few days ago. I just wanted to see if it worked. It did. I ran a scan, had zero codes which is no surprise. I have never seen the check engine light come on. Not bad for a 95 z28. Was loaded onto a laptop with windows 10.
#416
Gary
Thanks for all the information and software. I got the ALDL cable that was posted and used Win10 with no issues. I was able to see the codes that I needed to clear to move on with charging the AC. Thanks again
#418
Hey Gary,
Your software is great. Thanks for making it.
I wasn't able to find a guide on the ABS actuators and what they do, particularly if I want to activate the abs module to bleed it.
I see LF/RF Sol, Motor Apply, Motor Release, Rear and Home.
Can you provide some clarification?
#419
Prominent Member
I'm afraid I can't help much. I am a bit more of a computer geek than a car expert. The information for the actuators you mentioned came from a Tech II scanner. You might try downloading the service manual for the 94. It has a lot of info on the ABS system. I can tell you that I DID NOT include the brake bleeding routine in the app because it was rather complex and I did not feel comfortable generating it without full testing.
#420
I did that and bled the abs block out. I honestly don't know what exactly it means to home motors or if you need to do it more than once (which I did, just to be safe) but I was able to safely get the dirty brake fluid out of my abs module and it all worked out.
