Not too sure about the Velite as the basis for the 5th gen.
Re: Not too sure about the Velite as the basis for the 5th gen.
Originall posted by Z284ever
Okey-dokey, if that's your personal preference...fair enough.
But remember when I mentioned the overall length of the SN95 Mustang and G35 Coupe?
Camaro enthusiasts should start acclimating themselves to that.
For myself, 108 is a magic number as it was the first gens wheelbase. Besides that puts it between the two aforementioned vehicles. With the longer than-it-has-been-for-almost-25-years wheelbase, and modern packaging, it could be one hell of a spacious yet intimate car with much more appropriate dimensions.
I find it almost laughable that the Camaro, because of it's interior was classed as a compact when it's exterior dimesions screamed intermediate. Well, not quite as laughable as the new Magnum being classified as a truck.
And IMO, it's about time.
Guy, your last post about how the Velite gives the appearance of "big" is very true, and reminds me of the Buick Y-Job. They did a lot to make the car look "big" when it really wasnt.
The very large front grill, as well as the bulges and everything makes it look like a boat, but again with different sheetmetal with more agressive lines, I think the car will look much different.
And is it me, or is the SN95 much larger then the G35?
G35 Coupe = 182.2 " in length.
Mustang = 183.2"
Ford Explorer = 189.5"
Hummer H2 = 189.9"
2002 Camaro = 193.5"
You guys don't have a problem with that?
Mustang = 183.2"
Hummer H2 = 189.9"
Mustang = 183.2"
Mustang = 183.2"
I'm surprised because the G35 I saw yesterday looked much smaller than my Mustang. However, its TOO small IMO.
2 things with that is the back seat will be useless. SN95's have a very tight back seat, and the G35 is equaly worthess.
I needs to be bigger.
Originally Posted by jg95z28
That's all the difference?
1"....that's the difference. IMO, that's about perfect for a 5th gen, too.
But, don't you have a problem with Camaro being longer than an H2?????? Because, I think it's nothing short of simply ridiculous.
Why stop there? Let's make Camaro a 5 seater while we're at it. How about a third row?
Sure my 4th gen is long, but its still a hot looking car and proportionate for the way its styled. My 96 Mustang GT looks proportionate and its a heck of a lot shorter. The G35 is just too damn small to ever be a Camaro. Yes its the same size as the Mustang, but it looks like a small sports car based on its proportions. Compare the H2??? Why? Its a flippin SUV and a SHORT one at that.
You can't simply compare apples and oranges and you can't base everything on the length of a car that you haven't seen or doesn't even exist (in production trim) at this point.
The length is not nearly as outrageous to me as the short wheelbase as a ratio to overall length. on the 4th gen nearly 50% of the car is outside the axles. I think anything at or under 190 inches in length is fine as long as the wheelbase is significantly longer than 101 inches.
I'd rather have a sports car than a speed boat...
Anyone ever notice that since 1967 the Camaro's interior has remained roughly the same size but the exterior has grown by leaps and bounds? And as others have pointed out....all while other cars were shrinking on the outside and growing on the inside.
Forget about comparing numbers and compare what the cars actually look like.
Originally Posted by Z28Wilson
No shorter than 185 inches and no longer than 190. Put the car in that window, add just a touch more usability in the back seat and you've got ideal Camaro dimensions IMO. Styling is a whole other topic.
THANK YOU! Z284Eever you gush about how the '05 Mustang looks and feels but in pure dimensions you do realize that the car is a paltry 4 inches shorter (actually less!) than a 4th Generation Camaro, right? It isn't pure numbers of a car; a car can have length if it wears it well.
Ummmmm, no.
First, I wasn't gushing about the '05 Mustang...I was describing it. In fact, if you go back and read what I wrote...I believe that I mentioned the '04 Mach 1, Ford had on display there, seemed sportier than the '05 GT to me....when viewed externally... because of Mach 1's shorter length. The SN95 is 4" shorter than the '05. That mere 4" altered my perception of which car appeared more sporty. Frankly, I'd like the '05 better if it were abit shorter....all of it out of the rear overhang.
Second, the '05 Mustang is more than 4" shorter than a 4th gen....the '05 Mustang is 187.6" long...the 4th gen is 193.5".
