Motor Trends Alpha facts"
Why?
I submit the following for your consideration:
It looks just as good scaled down to me.
Of course, scaling down an entire car is massively more complex than scaling down an image (
), but that's not the point. The point is that you can scale down the whole thing, and it will still look good. You'll alienate some of the taller potential buyers, but the 5th gen is already extremely accommodating in that regard, and so I would venture to say that not very many customers would be lost.
3rd and 4th gen Camaros are classified as "subcompact" by the EPA. That's the smallest size class there is. The 5th gen is a "compact," which is one size up.
To be honest, I think the 3rd and 4th gen feel roomier (due in large part, I suspect, to the hatchback, t-tops, and lower beltline -- more light gets in).
While I'd love for Camaro to be a BMW crusher, I don't think that's the right direction. Camaro needs to remain more affordable than 3-series.
I agree in spirit, but "nearly chest high"? Seriously? How tall are you? I'm only 5'8" and as I recall, it's roughly waist-high on me. I'll walk out to my coworker's new 1LT and check for you later.
This is, of course, your opinion, and you're welcome to it, but I think that what makes the 5th gen unique and desirable is the aggressiveness of its styling cues -- the sharp angles, the long hood, the stance.
The 2006 Camaro Concept was only significantly larger in width, which has essentially no bearing on how the wheels look.
I think the ideal wheel size on the 5th gen is 19". 20" is passable, but too big IMO, and 21/22 is excessive. However, I'm one of those crazy people that cares about weight, and about the fact that the tire sidewall is an important component in the car's suspension.
), but that's not the point. The point is that you can scale down the whole thing, and it will still look good. You'll alienate some of the taller potential buyers, but the 5th gen is already extremely accommodating in that regard, and so I would venture to say that not very many customers would be lost.To be honest, I think the 3rd and 4th gen feel roomier (due in large part, I suspect, to the hatchback, t-tops, and lower beltline -- more light gets in).
Some manufacturers get "around" this issue by using visual tricks, such as having "hips" at the front, and the hood rising an inch as soon as it's past the fender wells. Look at the latest BMW 5-series.
You can make the Camaro smaller, and I don't doubt the designers will do a good job with it, but the point is, you are limited by regulations.
Okay, I said that with abit of sarcasm, but nevertheless, it's high. And contrary to some assertions here, GM Design has had to struggle to create a proportional design off of these hefty bones. Massive wheel openings with large diameter tires (18s, 19s, or 20s - they all require a 729 mm tire) is one example. Bolt a 3rd gen IROC-Z wheel or 4th gen SS wheel onto a 5th gen and see how it looks.
A smaller car lifts all sorts of styling restrictions to great proportions.
I seem to recall seeing your picture posted here once or twice. You were at the 5th gen concept reveal in 2006. You seemed like a normal-sized guy to me -- almost certainly taller than I am.
I added some emphasis for you. Please read again.
If you look at concept cars, they all have bigger hoops to make the cars seem more stylish than with the standard smaller spec wheels. See the concept Camaro had 21"-f/22"-r wheels. That's because it was substantially larger than the current production 5G and in perfect proportion.
You know, alot of people say that the production car looks EXACTLY like the concept. I really disagree with that.
Yeah, I know about the LSX conversions into BMWs... but if you are a manufacturer, you'd also leave some room in there for possible future developments, like twin turbos.
I know, I forgot to add that bit originally. But if the engines are getting smaller, then there is really only one alternative to boosting power - forced induction. Most V8s tend to be S/C because there is room above the V for it.
I do wonder how much room you need to have TTs with that smallblock, though.
I dare say you cannot have something as small as a 3-series sized engine bay for a TT LSX.
Let's say I create a classification of cars for anything with great handling, and I include the Mazda Miata. Would you come up to me and tell me that the Miata has no place in that category because it doesn't have enough horsepower?
Why?
), but that's not the point. The point is that you can scale down the whole thing, and it will still look good. You'll alienate some of the taller potential buyers, but the 5th gen is already extremely accommodating in that regard, and so I would venture to say that not very many customers would be lost.3rd and 4th gen Camaros are classified as "subcompact" by the EPA. That's the smallest size class there is. The 5th gen is a "compact," which is one size up.
Practically, you cannot just scale things down by 5% for example. The design/manufacturing process just doesn't work that way. Not only is it sometimes impractical from the moment you get into the car and sit in the seats, some items cannot be scaled down (like roof pillars and other structural components, engines, transmissions, washer reservoirs, stereos, seats (if you want to accommodate same sized adults) etc... and would eventually eat room from space for other components.
The scaled down car would always feel awkward to sit in. An average sized adult would instantly feel the difference from a scaled down car (say 15/16 = ~6% less real estate) compared to a smaller car, sized to accommodate the same sized person. Isn't that kinda obvious?
As muckz also pointed out, what about crash standards? I'm not sure a scaled down car would pass crash tests in the same way?
The point I wanted to make in regards to the wheel size was that Camaro shod with 20" wheels looks better than with 18" wheels... as do most cars i.e compare the standard car against the top of the range model. Still not convinced? Case in point, why are concepts always fitted with bigger sized wheels?
I dare say you cannot have something as small as a 3-series sized engine bay for a TT LSX.For me, a smaller, lighter Camaro, with a normally aspirated Gen V smallblock of 450+ or so horsepower is more than ample. In fact, it suits me just fine.
