2013 GT500 Base MSRP = $54,995
Old May 20, 2012 | 07:07 PM
  #301
WhiteHawk's Avatar
Re: 2013 GT500 Base MSRP = $54,995
My point is, that the 5th Gen Camaro has absolutely NOTHING to be embarrassed about.
-Geoff
Old May 20, 2012 | 08:05 PM
  #302
Gold_Rush's Avatar
-Geoff
Neither car has anything to be embarrassed about.
Old May 21, 2012 | 06:42 AM
  #303
Dan Baldwin's Avatar
Originally Posted by Dan Baldwin
"Knockout blow" is funny terminology to describe what a low-12s/120mph car does to a mid-11s/126mph car...
Nice made-up numbers. Who was your made-up driver when those times came out?
2013 Ford Shelby GT500 road test data and specs - Motor Trend
>>>Quarter mile 11.6 sec @ 125.7 mph <<<
Mid-11sec, ~126mph
The only difference you will see in 1/4 mile times will probably be the GT500 with a little more MPH. Neither one will be able to get down the track very efficiently. I don't see 2013 GT500 being any faster than the 2012.
You do now!
I mean seriously - what do you do for a car that doesn't have enough traction to get down the track now - another 110 horsepower should help!
-Geoff
Yup
Old May 21, 2012 | 09:09 AM
  #304
BigBlueCruiser's Avatar
Mid-11sec, ~126mph
You do now!
Yup
Uh huh
Old May 21, 2012 | 09:12 AM
  #305
To whom?
I said that *if* the difference was only a tenth, that'd still be a GT500 win. I think the real difference in ET, all else equal, is going to be more like 3-5 tenths.
I'd tend to call a tenth "close" rather than "an embarrassment" anyway, but maybe the ZL1 *should* be embarrassed to weigh over 4100 lb...
If I beat a 350Z by just a tenth of a second in my 375hp 4200lb Challenger, I'd be embarrassed.
But based on the 11.6@126 reported above, there's no danger of the GT500 being embarrassed. Now it's the Z06's turn.
Old May 21, 2012 | 09:47 AM
  #306
WhiteHawk's Avatar
Mid-11sec, ~126mph
You do now!
Yup
If you ran a ZL1 on the same day with the same driver it would mean a lot more. It should be even faster than .5 seconds by my calculations. Car is a beast though.
(Yet still no ring times).
-Geoff
Old May 21, 2012 | 10:02 AM
  #307
WhiteHawk's Avatar
Here is why you will never see Ring times. It actually went down in lateral G's from the last model even though it is said to be easier to drive.
Geoff
During our figure-eight testing, the GT500 posted an impressive 24.2 sec @ 0.80 g result, managing an equally impressive 0.98 g (avg) lateral acceleration. Even better: comparing the new Shelby to its predecessor, testing director Kim Reynolds declared it, "simply a much easier car to drive." Part of the improvement is attributable to the Torsen differential -- another piece of the SVT Performance Package - that provides a full-time torque-sensing system to help optimize traction and handling. Still, the old car, while more of a handful, was no slouch, edging its successor with a figure-eight time of 24.0 sec @ 0.82 g and maximum lateral acceleration of 1.01 g (avg).
Read more: 2013 Ford Shelby GT500 First Test - Motor Trend
Old May 21, 2012 | 10:11 AM
  #308
bossco's Avatar
Its to bad there isn't some sort of "drag pack" wth a more conventionally geared transmission. I'm reading the car does 130 in 3rd If its was geared similar to my car the 0-60 run might suffer (since you have to shift into 2nd around 40 or 50 mph) but it would probably knock a coupla ticks off the 1/4 mile time.
Old May 21, 2012 | 10:50 AM
  #309
Didn't you previously say:
? That would have been low/mid-12s. But now you're saying it should be quicker than 11.6?
C'mon, give it up, I called it
Old May 21, 2012 | 12:19 PM
  #310
King Moose SS's Avatar
I'm surprised neither of the Big 3 auto makers are doing a drag pack for any of the cars. Considering most pony car buyers go to drag strips over road courses.
Old May 21, 2012 | 03:39 PM
  #311
Bob Cosby's Avatar
130 in 3rd gear is a lot....but if the car is doing 125+ in the 1/4 mile, you're not far from a 4th gear shift before the traps - which a lower gear (higher numerically) would certainly bring on. Of course, as a drag racer, I would go the more gear route, but make it so that it would run very close to redline in 4th gear, making that extra gear change worthwhile.
I haven't done the math (haven't gotten bored enough yet), but I suspect something around a 4.10 would be required to do that (assuming 4th is a 1:1 ratio, as most are...MT82 excepted).
Old May 22, 2012 | 05:41 AM
  #312
Marc 85Z28's Avatar
Keep in mind that everyone else who tested the car is going significantly slower than Motor Trend. All those slower times are actual. Motor Trend used a correction factor
Old May 22, 2012 | 07:23 AM
  #313
ImportedRoomate's Avatar
Both GM and Ford acknowledged that most of the only racing that the two cars will see is at the drag strip, so they did make sure to build in durability for that kind of abuse. Inside line mentioned that at the GT 500 press event 5 test cars made about 150 passes that day - with drivers new to the car and without a failure. The gearing might not be the most desirable but everything else is built for it.
[autostream]http://autostream.com/camaroz28/?page_type=firebirdplayerthumbnail&framepage=2641& transactionid=1337689422-7610844202&posted_by=ImportedRoomate_www.camaroz28 .com&youtube_video_id=FGxhhgk4xB4[/autostream]
Old May 22, 2012 | 03:05 PM
  #314
Sax1031's Avatar
I wouldn't call 11.81 @ 125 mph significantly slower.
Old May 22, 2012 | 09:35 PM
  #315
roccopewterss's Avatar
God, these heavy-*** new cars are disappointing.
I was enamored with both the 5th gen and the GT500 when each came out. I appreciate the sheer insane amounts of power these cars are making from the factory. But this getting ridiculous.
Mid 11's with a motor that is closing in on 700hp at the flywheel...700 F*%#ing horsepower and you are running mid 11's! Congrats...you built a mkIV Supra ( I kid, I kid)!
Same with the Zl1...just disappointing..high 11's low 12's...give me a break.
Re-engineer these cars...start over...let them weigh no more then 3200-3400lbs...400-450hp would be more then enough...mpg would jump up...build a real 21st century drivers car.
In my opinion we are officially at the point of diminishing returns in the horsepower wars.
/getting old rant
