Progress on repaint of 96SS to Millennium Yellow!
Old Aug 30, 2002 | 04:13 AM
  #76
Brent94Z's Avatar
Super Moderator
Cool
<font face="Verdana, Arial" size="2">Originally posted by leftudoa:
Hey brent you may want to ask him to give you the little bit left that is all mixed and ready to rock so that God forbid you get a scratch or ding you could touch it up. Just a thought, looks killer, I think some black outs on the front and rear will really stand out too.</font>
They guy's shop is actually right down the road from me. If anything happens to the car, I'll just take it to him to fix
Brent Franker * Main Page
94 Vortech Z28 * 96 Z28 SS #1655 & #259
4th Gen Appearance Modification Guide
F-Body Install & Fix-It Guides
Old Aug 30, 2002 | 04:17 AM
  #77
Brent94Z's Avatar
Super Moderator
Cool
Hey Bralgar, good info! I'll ask him about this. I have heard him mention how this paint is reduced more than normal so I *think* he may already be doing that.
Also, this guy has painted yellow before... several times I believe. He originally did expect it to take more paint (like 5 coats or so) but didn't expect it to take 5 gallons. He has also been doing this for about 30 years. Dupont has sent him all around the US going to different "schools" and such to keep him up on what's going on I guess.
I'll ask him about this different mixing your are talking about to see what's up
Thanks!
Old Aug 30, 2002 | 08:38 AM
  #78
Bralgar's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Brent94Z:
</font>
No, what I was saying is it gets reduced 50%less than normal not reduced more. It get's 50% more actual paint per gallon that way.
Old Aug 30, 2002 | 10:07 PM
  #79
Brent94Z's Avatar
Super Moderator
Cool
Hey Guys!
Hood is painted Lookin pretty good! These pictures are from yesterday. Looks like I'll be getting the car back TOMORROW! They have some stuff left to put back on the car and some other little items. I was there this afternoon and they were wet sanding the hood. It is looking pretty good! There are some pictures here of the hood before wet sanding
With some luck, I'll get the car back tomorrow! Very cool
http://www.bfranker.badz28.com/fbody/ssrepaint.htm
Old Aug 31, 2002 | 07:50 AM
  #80
Central PA Z's Avatar
Post
Hey Brent, first off - even though I am not a fan of yellow.....the car turned out killer, very nice. Next, off subject, what is that box on the R side of your intake?? It has red, brown and blue wires attached to it. Just wondering.
~John
1994 Z Car
www.slfba.com
The usual stuff on a set of Nittos and a dead posi.
60' = 1.920
1/8 = 8.368 @ 83.88
1/4 = 12.968 @ 108.04
Old Aug 31, 2002 | 08:11 AM
  #81
Brent94Z's Avatar
Super Moderator
Cool
<font face="Verdana, Arial" size="2">Originally posted by Central PA Z:
~John
</font>
I'm not a big fan of yellow either but I like this particular yellow and I wanted to do something a little differe too
As for that box... it is called a Volt Blaster. What it does is at anything greater than around 93% throttle position it, you could say, over-rides the voltage regulator in the alternator and causes the alternator to put out about 14.5 volts. It'll put out this much voltage at wide open throttle where as typically your voltage drops to around 12 at wide open throttle. The major benefit here is that the extra ~2.5 volts greatly increases the capacity of your fuel pump (because it spins it faster at the higher voltage). So, if you are borderline on your fuel (as I am with 450 hp and a stock fuel system!) it'll help you out and prevent you from running lean. I also have one of these on my supercharged 94Z (install is better because I did it myself on that car. ) which has a fuel management system. I noticed an increase of 10 psig fuel pressure with just the addition of the Volt Blaster. On cars without a fuel management system you'll see no increase in fuel pressure because your regulator will just open further to dump the extra fuel back to the tank to maintain its normal pressure setting. However, if you are running on the edge of your fuel system and your fuel pressure drops to say 30 or 35 psig at WOT, chances are good with the addition of this gizmo you'll get your fuel pressure back up to 45 or so psig at WOT. A supposed side benefit of this Volt Blaster is that it helps your ignition system. I don't know about that but I do know it works well for the fuel system Also, both the point at which it kicks in (93% TPP on my car) and the voltage it goes to (about 14.5 volts on my car) are adjustable. If you want it to kick in at 80% TPP you can adjust it to that and if you want it to go to only 14 volts, you can adjust that too.
Old Aug 31, 2002 | 05:04 PM
  #82
dlx3200's Avatar
Thumbs up
I have a 97 Millennium Yellow Z. I think you will like how it turns out. I get alot of people looking at my car. Everyone says it stands out. Good luck! Hope it turns out ok.
Old Aug 31, 2002 | 11:55 PM
  #83
6LITEREATER's Avatar
Thumbs up
Your car definetly looks awesome! I got lost in all the posts though, what happened to a black roof, black mirrors and black 35th Anniv style stripes like the red ones you had (they looked awesome!)???
Old Sep 1, 2002 | 08:14 AM
  #84
Brent94Z's Avatar
Super Moderator
Cool
Very cool, dlx3200! Do you have pictures? I'd like to see how yours came out!
5LITEREATER, black roof is gone, black mirrors are gone, and no black stripes... at least not to start with I might add them later down the road but for now it's just going to be yeller!
Old Sep 1, 2002 | 09:57 AM
  #85
transam8's Avatar
Post
Looks great Brent. I like everything painted yellow, it looks really clean.
-Mike
99 Onyx Black SS A4 #2373
BMR SFC's, BMR STB, BMR LCA's, FLP L/T's, Magnaflow cat-back, Direct-flo lid w/Holley filter, SLP bellows kit, ppolished MAF ends, ported and polished TB, SLP bow-tie grille, Sullivan pedals, MacEwen gauges w/ T/A bezel, Mike C's SS frc's,
Old Sep 2, 2002 | 09:08 AM
  #86
dlx3200's Avatar
Thumbs up
The car is alot brighter than what the picture's show.
http://photos.yahoo.com/dlx3200
Old Sep 5, 2002 | 07:20 AM
  #87
ProjectRS's Avatar
Post
Brent, its Thursday! Is the car done yet?????
i cant wait
~99 Anniversary WS6 M6 #1133~
White with Blue Stripes/Rims
White Leather - T tops
3" Flowmaster cat back
10K Miles <A HREF="http://projectrs.homestead.com/ws6.html" TARGET=_blank>
http://projectrs.homestead.com/ws6.html</A>
~95 3.4 White Camaro~
Wings West GFX
High Rise Wing and more!
SOLD on 4-16-02
97 Grand AM GT ---&gt;New daily driver
88 LeMans My POS
Old Sep 5, 2002 | 01:28 PM
  #88
Grn96Z's Avatar
Post
come on!!! I have been waiting a few weeks for this. I want to see the final product, the car looks like its coming out great though. I just hope u get it back soon
Old Sep 5, 2002 | 04:20 PM
  #89
Brent94Z's Avatar
Super Moderator
Cool
LOL! Yeah, I've been thinking I've been going to get it back each day this week but doing all the "little" finishing stuff is taking time. I talked to them about 30 minutes ago and they were actively working on it and making sure all the panels are lined up right, painting the rockers underneath, and doing some minor touch up stuff. They see no reason why they can't "really" finish tomorrow and give it back when I get off work late in the afternoon!
If that's the case, I'll have some pics this weekend. WOOHOO!
Old Sep 5, 2002 | 05:11 PM
  #90
pu12en12g's Avatar
Talking
DLX: Great Pictures... did you get your z custom painted too ?
~Black 95 Z A4 Convert~
View My Modlist
P t ' s w e b p a g e
