Interesting LT1 to distibutor find...
Old Oct 26, 2004 | 07:55 AM
  #61
1994TransAm's Avatar
Re: Interesting LT1 to distibutor find...
does anyone have the measurements to do this mod on a lt1 intake?
i have a distributor ready to go!!!!!
Old Oct 26, 2004 | 09:29 AM
  #62
atljar's Avatar
NO i dont have any measurements for the cutting of an lt1 style intake. I know it can be done, and has been done. Also have heard good things about www.lt1intakes.com, but you have already found that site. Good luck.
Old Oct 26, 2004 | 03:03 PM
  #63
i have 1 intake cut up for the egr boss removal... which i think is going to be a must for this mod, all i did was take a sazzall and a grinder and remove the material off of the back of the manifold. its looks a lil messy, but once i go over it was a small grinder wheel, i'll be able to clean up the holes and the cut lines before i weld them clean with a plate of aluminum..
i'll try and get pics up of the finshed product before i weld by the end of this week, pics will be process by process!!!!!
good luck to all who try this... looks like its a 100$ to mod the intake for the hole... then you need to remove the egr boss and weld up... shop told me 50$ but i'm gonna try myself and it was 150 for the msd #121-84697
so thats 300 and i'll never need an opti fix again!!!!!
Old Oct 26, 2004 | 04:32 PM
  #64
OneFlyn95z28's Avatar
I ordered a MSD #8489 and #8531 to be delivered 2nd day from jegs for $195!
The Intake need to go back to the welder for some other work so I will just get this done while I am at it
Hope fully I will not have to cut up the EGR stuff to much as we would like to keep it. The intake Is the prototype for a prodution run if all goes well
Old Oct 26, 2004 | 07:09 PM
  #65
IrocSS85's Avatar
well then where's the pics of your intake? we wanna see too. if all goes well, how much you gonna ask w/exchange?
Old Oct 26, 2004 | 09:52 PM
  #66
sseeya's Avatar
Originally Posted by 96Z28SS
Yes there is no opti on my car got rid of it all together. I had the FAST system already I had the opti, I had problems, I had the ls1 coils, I had problems, I put the distributor in it and no problems. Total time it took to make the hole in the intake and welding a piece of aluminum to get the right height was probably about 1 hour, I can't weld aluminum so i had to take it to a welder.
The distributor doesn't need to be wired to anything in my application.
I'm a little confused. What distributor are you using? Where does the 'puter get it's reference signal from? Are you using a crank trigger?
Old Oct 26, 2004 | 11:02 PM
  #67
His post is a little misleading. He still has the Opti, and he's using the high and low res pulse signals. I clarified that in a post several below the one you quoted. Gotta read the whole thread.
Old Oct 27, 2004 | 02:29 PM
  #68
sseeya's Avatar
With all due respect Fred, I did read the whole thread and I was still confused. There appears to be two different people talking about doing this swap. One is altjar. Who started the thread, he is still using the optical part of the optispark and the stock PCM. I understand that.
The other guy, the person I quoted, is 96Z/28SS. He is using the Fast system and claims to have removed his optispark all together. No where in his post did he mention anything about still using the high and low res pulses from the opti. That's why I asked.
Old Oct 27, 2004 | 03:30 PM
  #69
LT1 Bunny's Avatar
he would have to be using the crank trigger and sends that to the FAST system.
Old Oct 27, 2004 | 05:25 PM
  #70
96Z28SS's Avatar
Yes thats right with the FAST system I took the opti out, I'm running a crank trigger infront of the crank pulley. on my website you can see pictures of the crank trigger and picture of the timing cover with no opti holes in it, I had them welded shut.
Old Oct 27, 2004 | 08:08 PM
  #71
Damon's Avatar
REGARDING CUTTING A DISTRIBUTOR HOLE IN THE BACK OF A STOCK LT-1 INTAKE.....
There is a guy by the name of John Millican over on Thirdgen.org (and other places) who does conversions of LT-1 intakes for use on earlier (non-LT-1) small block Chevys.
Who cares? Well..... one of the things he does is drill them out for use with a typical gen-1 SBC rear distributor. Might want to track him down and ask a few questions. The few times I have corresponded with him he was very cordial and freely gave information on what he knew.
In fact, I asked him about this procedure specifically and, as I recall, it was pretty simple and didn't require super-tight tolerance machining to make it work properly.
Old Oct 27, 2004 | 09:06 PM
  #72
nope with a slip collar Distributor like the one listed it should be easy to set up.
I am going to just have it built up where the Dist goes and then mill it flat. next i will bolt it to the block and use an old distributor to mark and cut the hole
Hope fully it works out!
Old Oct 27, 2004 | 10:11 PM
  #73
dkeers's Avatar
On your website, one of the pictures mentions that it was "a bit of a pain" to get the distributor in. Does that mean you can get it in and out with the engine in the? Or is the "pain" the fact that you have to drop the engine down. I always figured you would have to lower the engine a little bit. I suppose that dropping the engine down a little bit is not much harder than getting to the optispark is anyway.
Dustin
Old Oct 28, 2004 | 08:55 AM
  #74
96Z28SS's Avatar
Dustin
Its a bit of a pain cause you need to drop the k-member just a tad.
Its alot easier than swaping out an opti-spark. With the removing the opti you need to drain the coolant and need new waterpump gaskets and its just a big pain in the butt. With the distributor in the back the way I see it is, its maintenance free, if you need to change the cap or rotor its easy to get to no need to pull the whole distributor out. So droping the k-member you only need to do it once. You only need to remove the 6 bolts on the k-member and lift the body an inch or so, you don't need to completely drop the motor you can leave the brake lines, coolant lines, and swaybar all attached its so simple to do.
Old Oct 28, 2004 | 09:37 PM
  #75
Well I got my Distridutor today. It is much lower then the one 96Z28SS is using so it might come out a little better. I am hoping any ways
