Interesting LT1 to distibutor find...
Old Oct 30, 2004 | 12:16 AM
  #76
stockLT1's Avatar
Re: Interesting LT1 to distibutor find...
So If I am uderstanding this right, I can put an MSD dist. in the back of my intake and eliminate the opti blowing up over 7,200 RPM's??
I have been blowing up the cap and rotor, not the opti. My car could be alot faster if I could turn more R's
How high are you guys reving with the distributor conversion??
Old Oct 30, 2004 | 12:40 AM
  #77
OneFlyn95z28's Avatar
http://www.nwfbody.com/images/Ellis/Picture%20086m.jpg
A little hard to tell right now
Old Oct 30, 2004 | 02:55 AM
  #78
SStrokerAce's Avatar
RPM is limited by fuel and spark maps in the ECU, not the opti. Going to another ECU setup or a strait distributor is going to get you more RPM.
Bret
Old Oct 30, 2004 | 02:56 AM
  #79
Originally Posted by OneFlyn95z28
that's a rusty block boss!
Old Oct 30, 2004 | 10:44 AM
  #80
Well I just got it back yesterday and it aint rusty no more
Todays goal. Put up more insulation in my shop and start rocking it baby!
Old Oct 30, 2004 | 08:14 PM
  #81
atljar's Avatar
Bret
Bret-
The obd2 computers have rev capabilities past 7k, though they are a PITA to tune up there. The obd1 stuff will actually shut off the engine if you hit 7k.
Anyways, i think the problem he was referring to is the opti rotor imploding. On cars that rev higher and rev fast up top, the opti rotor will actually fling itself apart inside the casing destroying pretty much everything. Thats why i removed the rotor itself from inside the housing.
Old Oct 31, 2004 | 01:41 PM
  #82
arnie's Avatar
Originally Posted by LT1 Bunny
I also like how the dis. is mounted in the back like they should be.
I find that an interesting comment. Long B4 this forum was someone's imagination, the complaint was why didn't chevy put the distributor in the front, where it belongs, so you can work on it. Quite amusing!
Old Nov 3, 2004 | 07:19 PM
  #83
texlurch's Avatar
Well, I am just about ready to do this mod. Only problem I have is firewall clearance. I know the firewall won't clear a standard HEI with out a BFH, so how big around is the crab cap?
Then I had another thought. Why not just run down to Autozone and pick up a standard old point style distributor setup for $70 or so, and weld the advance plate to the shaft? Sure it doesn't say MSD on it, but it has the cast iron gear and a new Accel cap and rotor. And the small diameter gives a lot more room back there.
Anyone see why it couldn't be used?
Old Nov 3, 2004 | 08:50 PM
  #84
Well the MSD is MUCH lower the Crab cap is four inches lower then the one you are thinking about The rotor body it self is a good 2 inches shorter also
later
Old Nov 3, 2004 | 10:11 PM
  #85
texlurch's Avatar
later
Luckily, I don't have any overhang like the 4th gens on my 68. But the firewall is real close to the back of the block, and I know from experience that a stock HEI will not clear.
I might look at something from a TPI, I think I can run the DFI off that also...
Old Nov 5, 2004 | 08:24 AM
  #86
1994TransAm's Avatar
my intakes are on thier way back from LT1intake.com, john does great work so i'm excited!!!
after that i just slap it on and throw the motor in
Old Nov 5, 2004 | 11:53 PM
  #87
texlurch's Avatar
Please post or email a pic! What kind of turn around time was it?
Old Nov 6, 2004 | 10:14 AM
  #88
OldSStroker's Avatar
Another vote here for front mounted distributors. With the dist. driven off the cam, driving the cam from the front and then using it as a constantly winding/unwinding drive shaft to drive the dist. doesn't help control spark timing.
Remember the SBC was designed in the early 50's to be a cheap to produce, but still powerful engine. With a rear oil sump dictated by the chassis design of the time, putting the oil pump/dist. drive in the back was the most economical thing to do.
The intake and exhaust port layout was dictated more by less complex manifold casting than by power or cooling considerations. Intake ports share a wall in the manifold, and there are only 3 flanges (fewer bolts) on the exhaust manifolds.
Shoebox Chevys also had tons of room in the engine compartment to get at the distributor.
My $.02
Old Nov 6, 2004 | 08:06 PM
  #89
NOMAD's Avatar
Originally Posted by atljar
http://memimage.cardomain.net/member...06_14_full.jpg
Just got some pics back. Nothing of the distributor specifically, but you can at least see it here, and get a rough idea of clearance.
That pic sucks, my throttle body is no longer on there
-Shannon
Old Nov 9, 2004 | 11:54 PM
  #90
Sunsceamer's Avatar
What is the cost to have the intake modtifed?
I was thinking of using a friends LT1 carb intake and take a piece of sheet metal as a templet for the valley pan or gasket with hole on the template to mark the hole. Also does it have to be a lt1 intake or could I use any small block intake to make a template?
