Interesting LT1 to distibutor find...
Old Nov 15, 2004 | 11:58 PM
  #106
OneFlyn95z28's Avatar
Re: Interesting LT1 to distibutor find...
Aljar. The biggest things besides what you covered in the last post is the Gear placement. If the gear is not running pretty much dead center of the gear it self(I.E. cheching the pattern like the MSD directions say) you will start eating up gears and cams pretty fast
I lost my first bronze gear in about two weeks That was along time ago and now I check EVERY one and ALWAYS try to use a slip collar. sure slip collar makes life SO much easier
Jeff did not get to start on it this weekend sorry. the intake IS off to the welder hopefully for the last time
Old Dec 5, 2004 | 05:53 PM
  #107
atljar's Avatar
An update since many of you asked. Tore the motor apart b/c it bent some valves, well lots of valves. Long story.
Anyways, the distributor can be removed with the engine in the car, and without dropping any of the front suspension down. You will need to remove the intake at the same time however as you must slide it forward, and you pull up on the distributor.
Old Dec 5, 2004 | 08:23 PM
  #108
So do you think it the hole was a little bigger, we have some room to play, it would come out with out taking the intake off?
Old Dec 5, 2004 | 09:53 PM
  #109
IrocSS85's Avatar
how could the hole be bigger, it would leak oil. maybe make an adapter to bolt to the intake, than the dist. would bolt to the adapter plate? that would work with a slip collar distr.
Old Dec 5, 2004 | 10:05 PM
  #110
atljar's Avatar
I cant see being able to get it out without totally pulling the intake, wihtout a HUGE hole (plate may work, good idea. I would do it in 2 parts, with semi circle in each half. That way it wouldnt be in the way when removing the distributor.) You need to get it at a pretty good angle so that it doesnt hit the wiper cowl.
Ellis...if i may ask. Why would you ever pull the distributor out at someplace like the track? I can only see removing it if a.) eats the gear b.) pulling cam or intake
If its misfiring they sell new caps and rotors which could easily be done on car on the fly.
Old Dec 5, 2004 | 11:33 PM
  #111
well lets just call it experiance. Sure as hell I can't get it out with out pulling the intake .... will be the first damn thing I ahve to do at the track
BTW I sheared a roll pin on one
Old Dec 6, 2004 | 12:08 AM
  #112
atljar's Avatar
Sheared a roll pin, what did you do, put it in backwards
F'n1996Z28SS
Aug 23, 2023 11:19 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Roadie
Feb 16, 2015 10:34 AM
Jason Short
Jan 19, 2015 06:34 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
