Assorted Newb questions
Old Sep 16, 2004 | 06:22 PM
  #46
Rice Killer87's Avatar
Re: Assorted Newb questions
if ur putting 350 heads on a 305,u better mill them b/c ur gonna lose compression which=bad.
L98 vette heads arent that much better than cast iron L98 heads,they are aluminum (which u know now) that weight less and dissapate heat faster than cast iron. but if your gonna spend 400 on a set of heads,u may as well wait longer and buy a set of cast iron Vortec heads in the $550 range and they will give u much better performance than those alum. L98's. but if u buy Vortec heads,u have to buy a Vortec specific intake b/c the intake-to-head bolt pattern is different.
since your talking about a majority street car,i would do the Vortec's...you'll be happier in the long run. those heads,a mild cam,good intake and carb...and ur car wound go low 13's w/ a 350,not sure about a 305.
hope that helps
Old Sep 16, 2004 | 06:43 PM
  #47
85_305's Avatar
Snap.. never even thought of the fact that I will be putting 350 heads on a 305; I forgot I would have to mill them Crap! So how much does milling tend to go for? I don't wanna go with Vortec; too expensive, and too much work and money to get the diff. intake.
ALL the help I have been gettting lately has helped me GREATLY, Ricekiller.. thanx for yours!
Old Sep 17, 2004 | 02:31 PM
  #48
Tru2Chevy's Avatar
Not really an issue with the aluminum L98's as they only have a 58cc combustion chamber. I think the cast L98 (the ones found on stock F-bodies) were 64cc.
- Justin
Old Sep 17, 2004 | 03:25 PM
  #49
85_305's Avatar
So will either head fit, or will I have them milled down?
Old Sep 18, 2004 | 01:08 AM
  #50
Tru2Chevy's Avatar
The 'vette L98s will actually raise compression just a pinch. They will work fine with the 305 will no work done to them at all.
I originally bought mine before I found the 400 block. The ideas that I have given you are all things that I was going to do to my 305.
- Justin
Old Sep 19, 2004 | 02:29 PM
  #51
85_305's Avatar
And the Vette L98's are ONLY Aluminum, right?
Well, I might be buying my Performer RPM.. TOMOROW with luck I can't wait! Then, I can do my valve seals, intake manifold, AND carburetor!
Do you think that these mods will make my exhaust note any different or meaner, or will it not effect it?
Old Sep 20, 2004 | 01:05 PM
  #52
Tru2Chevy's Avatar
Yes, the vette L98s are all aluminum, and non of the F-body L98's are aluminum.
You prolly won't hear any difference in the stock exhaust.
- Justin
Old Sep 20, 2004 | 08:13 PM
  #53
85_305's Avatar
What if my exhuaust isn't stock.. will I hear a difference?
BTW.. I think that now if I find a Performer for cheaper, by a large margin that is, than a Perf. RPM, then I will buy that instead.. I am almost to the point of being desperate for buying parts and putting the car on the road
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
kandied91z
Aug 4, 2002 02:53 AM
