Fpss????
Old Apr 9, 2008 | 01:26 PM
taylorcrzy's Avatar
Fpss????
Just wondering if this FPSS will work for me. My car is a fuel injected H/C car. If this one won't work then which FPSS will work for me. Thanks
http://www.jegs.com/i/NOS/741/15750/10002/-1
Old Apr 9, 2008 | 02:27 PM
Ray@NitroDaves's Avatar
That one is for a low pressure fuel system...it has a preset 5psi shutoff. The LT1 runs approx. 45psi fuel pressure, and needs a higher shut of capability.
http://www.nitrousoutlet.com/catalog...roduct_id=2553
this one includes the fitting you will need to connect to your fuel system.
Old Apr 9, 2008 | 03:03 PM
You have to order the correct pressure, NOS offers both low and high pressure adjustable switches:
Adjustable Fuel Pressure Safety Switches
Control your car's fuel pressure and avoid the risk of shooting nitrous with too little pressure to supply the extra fuel required. These heavy-duty switches are offered at 5, 7, 15, 30, or 50 psi.
Everyone uses the same pressure switch, made by Honeywell/Hobbs (although some outfit with "Pro..... " in their name is probably having rip-offs made in China by now):
http://content.honeywell.com/sensing...scorp/P3_6.pdf
Old Apr 9, 2008 | 03:19 PM
taylorcrzy's Avatar
Ray will that FPSS work with the NX Express brand solenoids?
Old Apr 9, 2008 | 09:29 PM
Moshbmx1's Avatar
I believe that a FPSS will work on any kit, doesnt matter the FPSS or the brand
Old Apr 9, 2008 | 10:57 PM
taylorcrzy's Avatar
Ok, just getting my kit installed and wanted to make sure before I spent money on a part that wouldn't screw into my existing fuel solenoid. Trying to make it look as clean as possible under my hood.
Old Apr 10, 2008 | 08:54 AM
FPSS are not brand specific....the difference between manufacturers is the fittings they use to attch the FPSS to the system. We use a manifold with multiple accessory ports. THis gives you a plce to put the FPSS and another item such as a fuel pressure gauge, without having to buy more fittings.
Kris96WS6
N2O Tech
May 8, 2004 11:14 PM
craigffb
N2O Tech
Aug 24, 2003 12:21 PM
snksknr94
N2O Tech
10
Jun 16, 2003 06:45 PM
snksknr94
N2O Tech
May 6, 2003 02:34 PM
Hawk
N2O Tech
Mar 30, 2003 10:48 AM
