fpss ?'s
Old Jun 7, 2006 | 10:54 PM
camzaro28's Avatar
fpss ?'s
have been trying to get my system working, which hasnt been workin out. but anyway
was looking at something and it dont make any sense. out of the relay i have the white wire running to one side of the FPSS, then the other goin to a chassis ground. ok ? is, wouldnt the FPSS ground wire need to go to the mallory instead of a chassis ground? to shut the system down if it wre to lose fuel pressure!!
i just dont see how it is doing any good that way i have it wired up at the moment.
thanks in advance
p.s. if it does need to go to the mallory 685, which wire do i conect it to?
Old Jun 8, 2006 | 01:57 AM
race u 2's Avatar
Re: fpss ?'s
I don't know how your relay is wired up but that would work if wired right cause when the fuel psi reaches it's propper psi that the switch is set at it would close the circuit and ground the relay wich is probley wired to the NOS solinoids so when the fuel psi goes bellow the set psi the circuit is the opened and not alwoing a ground for your relay
Old Jun 8, 2006 | 07:36 AM
Z28_LT4's Avatar
Re: fpss ?'s
If you want to use the window switch on the 685 then yes you'll need to connect the wire coming from the fpss to the violet wire on the mallory.
the violet wire provides the ground for the nitrous relay in the window you choose. ex: on at 3000rpm off at 6000rpm.
Old Jun 8, 2006 | 07:56 AM
camzaro28's Avatar
Re: fpss ?'s
here is the instructions i am using http://www.nitrousexpress.com/Instructions/stage1.pdf
on that it shows just grounding the FPSS to chassis, so that is what i have done. my violet wire off the mallory is now goin to the toggle ACC switch.
so do u think i should make a y off that wire and run it to the ground that i have for the FPSS?
thanks for the replies guys.
Old Jun 8, 2006 | 09:58 AM
01Z's Avatar
01Z
Re: fpss ?'s
Once again, I'm sorry for following you around but your threads always draw me in.
I'm a little worried about grounding from the arming switch through the mallory's window circuit because of the amperage required by those larger than mine solenoids.
I think using the the ground through the fpss is a better idea than the arming switch but still worrying about the current demands. As I've stated before, the mallory window ground is only rated to 10 amperes. Any more and we risk melting something.
Old Jun 9, 2006 | 11:16 PM
camzaro28's Avatar
Re: fpss ?'s
well i think i got it working now. everything clicked during the test. now i just have to wait for the rain to stop and the roads to dry.
thanks for all the help, the FPSS to the mallory was my problem
Old Jun 15, 2006 | 10:00 PM
2000GTP's Avatar
Re: fpss ?'s
So how did you solve the problem? Did you run the violet wire of the Mallory box to the ground on the arming switch or did you run the wire off the FPSS to the violet wire on the Mallory 685 box?
Old Jun 15, 2006 | 11:19 PM
camzaro28's Avatar
Re: fpss ?'s
oh, damn i updated some other ones, mustve missed this one.
yes i hooked the ground off of FPSS and hooked it into the violet on the mallory and worked the first time.
tested it out a few days later with 75 shot, worked the first time. had the bottle PSI low, so it didnt feel like much. i dont have 100 jets, so i put in the 150 and bottle psi at 1000ish ( have bottle warmer set at 1050-off and 975-on) and holy ****, huge difference. once again, these tires rule.
20ish roll with 150 shot, full bottle pressure, these tires dont even chirp. took down a LS1 that recently dynoed 380/450. passed him around 90 then he let out shortly after.
Old Jun 16, 2006 | 05:45 AM
2000GTP's Avatar
Re: fpss ?'s
Great, thanks for the update. Congrats. on your LS1 kill.
Kris96WS6
N2O Tech
May 8, 2004 11:14 PM
craigffb
N2O Tech
Aug 24, 2003 12:21 PM
snksknr94
N2O Tech
10
Jun 16, 2003 06:45 PM
snksknr94
N2O Tech
May 6, 2003 02:34 PM
Hawk
N2O Tech
Mar 30, 2003 10:48 AM
