Can I put a older 700R4 in my 94 Z28?
Old Apr 17, 2005 | 12:01 AM
Fat_Boy's Avatar
Unhappy Can I put a older 700R4 in my 94 Z28?
My 4L60E has 3-4 gears gone. I plan on having it rebuilt in a few months or just replacing it with a full race built 4L60E, I cant afford to do that just yet. My brother however has a older 700R4 thats in perfect working order just sitting in his garage that I can have to atleast use untill I get my 4L60E rebuilt, but I dont have a clue what I have to do to swap it in of if it even will. I know the 4L60E is a newer electronic version of the 700R4 but dont know whats different. Some one clue me in please. Also is there anyone on this site that rebuilds transmissions? I do eventually have to get this 4L60E gone through.
Old Apr 17, 2005 | 12:46 PM
Fat_Boy's Avatar
Re: Can I put a older 700R4 in my 94 Z28?
Anyone know of A site I can go to to find a quick answer to this question?
Old Apr 17, 2005 | 01:14 PM
Aloner's Avatar
I don't see why you couldn't. They should have the same bell housings, as I do believe the 4L60E is just an electronic version of the 700R4. Although the computer may be finicky about it.
Old Apr 17, 2005 | 06:22 PM
bing101's Avatar
I know physically it will bolt up and functionally it will work. You will have to rig up a TV (throttle valve) cable that kicks the tranny down (done elctronically on the 4l60E) it just connect to the throttle arm on your TB and runs down into the transmission. The clucth lockup can be done hydraulically (most aftermarket trannys will do this) or you can wire up a circuit that locks up the tranny in 4th gear with a switch and some wires.
The only problem you will run into is the trouble codes the pcm may throw but you can have those deleted maybe if you get a pcm reprogram.
Is yours OBD1 or 2?
Old Apr 17, 2005 | 06:42 PM
Fat_Boy's Avatar
So if I put a shift kit or valve body in it that lets me shift up or down manualy and drive it that way it should work ok?
Old Apr 17, 2005 | 08:04 PM
bing101's Avatar
yes and it will shift automatically on its own anyways even if its not hooked to a computer. what they mean by manual valve body is if you start in 1st gear th etranny will hold in 1st gear until you shift up or it blows up
If you put the car in D and start from 0 mph it will shift fine through 1-2-3 and 4 if you are in Overdrive.
Old Apr 17, 2005 | 08:17 PM
Fat_Boy's Avatar
I have yet to look at his 700R4, does the shifter cable hook up the same??
Old Apr 17, 2005 | 10:02 PM
bing101's Avatar
Yes it snaps onto a arm on the driver side of the tranny
Old Apr 18, 2005 | 12:58 PM
Fat_Boy's Avatar
I want to thank everyone for there help and information. Thanks to all!!
Old Apr 18, 2005 | 03:50 PM
1SlowFormula's Avatar
Did you actually come to an understanding of what was being said above? You need the TV cable for it to automatically kick down. I guess you could put it in drive and manually drop it down to pass someone and then put it back into drive again. But either way just get it rebuild right and then you don't have to worry about it.
Old Apr 18, 2005 | 09:56 PM
bing101's Avatar
Contrary to popular belief the TV is NOT A KICKDOWN CABLE.
If you dont hook yours up and misunderstand its use you will burn out your
tranny.
The TV cable moves the throttle valve piston in the valve body of the tranny and controls not only kickdown but overall shift points and the whole way your tranny behaves. This is why GM and about 100 other tranny sites all stress and have numerous diagrams about TV cable adjustment after an install.
If your TV cable is not hooked up right you will experience stacked shifts which are not really seperate feeling and your shifts will feel sluggish like your tranny is slipping. This will cause your tranny to run hotter than desired and heat is a trannys worst enemy.
Old Apr 19, 2005 | 09:27 AM
tranny.
Bing, thank you for clearing that up!
Old Aug 11, 2010 | 03:43 AM
hoursetraitor's Avatar
im leaning towards doing this on my car. from what ive found a 93 tb has a tv provision since the 4l60 is basically a 700r4 also. i found a write up someplace about how to trick the ecu by jumpering some wires.
for me i bought this car with 105k on it for $1500 and 2 months later i lost reverse but all my forward gears work. and i just cant get a 94 v8 4l60e for the price i can get a 700r4 at pull a part. its $600-900 vs $55 at pull a part. hell if i could i would remove the opti and install a hei. i mean i could but i dont want to go carb. and yes the tv= throttle valve not kickdown and ive seen trannys burn up without it hooked up.its crucial. i just want my car back on the road and i cant afford a t56 swap. aww the joys of being an unemployed mechanic
found this on here if anyone is lookn for info on the 4l60e
https://www.camaroz28.com/forums/sho...d.php?t=476780
and this too in regards to the 93 ecu and tb, problem is 93 is speed density but im pretty sure the tb can be used to get the tv cable
http://www.thirdgen.org/techboard/lt...-94-lt1-i.html
Old Aug 1, 2019 | 05:55 PM
BobbyMorrow's Avatar
Hey I also have a 94 camaro and a 700r4 with all electronics removed so would it bolt up?
Old Aug 1, 2019 | 07:40 PM
“Fat_Boy” hasn’t signed into this site since 2005. If you’re looking for an answer, might want to try sending email or a private message. Left click on his screen name for those options.
z28er_kgb
Dec 22, 2011 06:24 PM
94NDTA
9
Jan 19, 2007 02:06 AM
luis nunez
Feb 23, 2004 12:12 PM
Simba
Jan 28, 2004 04:56 PM
funina91ss
Jun 29, 2003 05:41 AM
