question
Old May 5, 2007 | 03:05 PM
eldiablo1988's Avatar
question
hey guys
right now i'm running 265/35/18 on my 18 inch Z06 rims.
my question is will a set of 245/40/18's fit on there?
as you can tell i dont know pretty much anything about tires and such.
thank you
Craig
Old May 5, 2007 | 03:07 PM
J96Z's Avatar
Well first off, what is the width of the wheel?
Old May 5, 2007 | 03:25 PM
Factory C5 Z06's are 18x10.5". You can't run a 245/40-18 on a 10.5" wide wheel. They fit wheels 8.0-9.5" wide. If you have an aftermarket 18x9.5" Z06 replica, it will be OK, but its going to look a bit "stretched" on a wheel that wide.
Even the 265/35-18 is not a good choice, since its smaller in diameter than the stock tires. Most people opt for a 285/35-18 to get closer to the correct diameter.
Old May 6, 2007 | 12:07 AM
i have the aftermarket 9.5" ones.
so the 245/40/18's will be alright?
Old May 6, 2007 | 01:45 AM
Zack's Avatar
why you going narrower?
Old May 6, 2007 | 02:40 PM
J96Z's Avatar
Go buy yourself a set of cheap 275's and be done with it. Anything smaller will look just that, too small.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
