What Intake, Headers, Exhaust, etc...?
Originally posted by Ramune
Wow, those are a small fraction of the price of the SLP intakes. So, I can just take these K&N filters and stick them in my current air box?
I just did a search though and it looks like the FIPK is for the 3.4l (93-95 Camaro V6 engine).
click here- Ligenfelter CAI for 3.8s
Originally posted by 99blackSS
If by cutting out the bottom of your air box you mean the free ram air mod, I don't recommend it (see a few posts up). A aftermarket lid comes with a hose to by pass the air silencer and has a place on the lid to insert the sensor. I don't know if SLP makes a lid for the 3800, I would go with a whisper lid.
Re: whisper lids are junk!!!!
Originally posted by lt1orls1igotbot
Whisper lids are junk between me and my best friend we been through 3 they are made of thin cheap plastic that will not hold up and sometimes get broke on installation I would not reccomend my worst enemy to use that junk!!!!!
I must be lucky
. I have a '97 M5 3.8l (I think that's how you say that.), and I'm having a hard time finding any CAI's for it. I've found one. Is this my only option? And if it is, is it any good?
I must be lucky
Re: What Intake, Headers, Exhaust, etc...?
I just purchased a 2001 v6 3.8, and I wanted to put a CAI, and I wanted to know which was better SLP or K&N? How hp will I actually gain from them, cause I know that the site says like 26 hp for K&N, and 20 hp for SLP. Does anyone know where I can get a good deal on either of these. SLP is like half the price of the K&N. Thanks.
I have a 99 3.8 camaro and i got the SLP cai, K&N filter and wisper lid all for around $220 shipped. As for gains I noticed more of a gain at higher RPMs. Im not familar with the K&N cai but the SLP is probably the best bang for you buck.
where did u get that deal at? was it hard to install, or would u reccomend that i get it done somewhere else?
I didnt know if my post that is in the v6tech section would be deleted so im putting it here too..
i have a 3.4L '95 camaro
What do you think my flywheel hp and rwhp will be with all this..
1.Headers
2.cold air intake
3.TB bypass
4.180 thermostat
5.underdrive pulleys
6.GM powerpack- ported cylinder heads w/3-angle valve job, new valve seals, ported upper and lower intake manifolds, and reground cam, hi-lift valve springs
7.Loudmouth exhaust
8.SLP air temp module - advances spark 1 or 2 degrees
9.New ignition coils
10.Platinum Plugs
11.8mm wires
1.Headers
2.cold air intake
3.TB bypass
4.180 thermostat
7.Loudmouth exhaust
10.Platinum Plugs
11.8mm wires
What are some good headers I can get for my 3rd gen? I want to get some more power into this engine without heavy modifications and I know that a good intake and good exhaust system is a good starter power adder. Also, it is possible to change out the headers in this car without a lift? I have ramps that get the front off the ground (used them to fix a loose bolt in the oil pan). Thanks for the help.
