3.4 horsepower increase
Old Jan 28, 2013 | 11:37 AM
  #16
Wild Willy's Avatar
Re: 3.4 horsepower increase
I noticed a big difference when I swiss-cheesed the bottom of the stock air cleaner box on my LS1- Since then I have gone a step further, and added a true CAI.
+1 on the gears, I swapped out the 2.73 fuel economy gears my Z28 came with (along with the steel driveshaft that comes with those gears) for a 3.42 rear out of a manual F-body that had been wrecked. I would have liked to go even deeper, I was running 4.10's in my LT1-powered Caprice, and that was a hoot to drive. Would chirp third gear at about 75 MPH. If you change your axle, you will need to reprogram your PCM.
Old Jun 14, 2019 | 02:58 AM
  #17
Jeremiah Decker's Avatar
how much hp do you think you where pushing
Old Nov 17, 2020 | 12:38 PM
  #18
95convertible's Avatar
Originally Posted by 93 LT1
I have done the follwing and from stock I felt a big difference.
K&N CAI ($289.99)
Pacestter 3.4L full cat-back ($400.00 installed)
J.E.T underdrive pulley ($69)
Stock LT1 one piece driveshaft ($10)
J.E.T. 160* thermostat ($15)
I used my 93 3.4 auto as an everyday driver as well. The car was a real turd stock..this woke it up.
could you send an example of your catback, i looked online and couldn't find one, also is it a drive shaft off of any lt1? thanks
Old Nov 17, 2020 | 04:48 PM
  #19
“93 LT1” hasn’t signed into this site since 2010.
All I can add is the fact the the driveshafts for the LT1 are identical for all years 1993-1997. Most of them are steel. A few were made out of aluminum for the cars with the 1LE option. But length and front and rear yokes are all identical.
Can’t help you on the catback.
Old Nov 17, 2020 | 04:53 PM
  #20
thanks
MarcellJ
Mar 14, 2014 12:21 PM
Affliction
Dec 1, 2013 11:51 AM
DeViLz Pr0d1gY
Apr 21, 2010 06:57 AM
V8 Slayer
V6 Tech
15
Jun 14, 2005 10:28 PM
SantaCruz163
Jul 16, 2003 09:54 PM
