Best way to make more power?
Old Nov 30, 2013 | 07:11 PM
Affliction's Avatar
I have a stock lt1 from my 93 camaro. Only thing done to it is K&N air filter.
The car is going bracket race car.
Looking to make some nice power using the lt1. Currently was thinking about a catback exhaust system.
What else could I do to add more power? For relatively cheap, as I'm a college student and don't have a ton of money right now
Old Nov 30, 2013 | 11:22 PM
Shemp 5's Avatar
Re: Best way to make more power?
aside from the cold air intake, a catback will make a noticeable difference(sounds better too haha), new headers would help too. Those are your basic bolt on's. if your budget is bigger a cam would definitely not hurt. A dyno-tune would probably help you make some gains after you do all the mods you want.
(pm me when you get a sec, im from the chicagoland area and ive got a 93 z too)
Old Dec 1, 2013 | 03:31 AM
John95z28's Avatar
To compliment the cold air intake, do the throttle body bypass of the coolant lines. Basically free. Throw some full roller rockers on too.
Old Dec 1, 2013 | 07:36 AM
parkers Z28's Avatar
What transmission A4 or M6 ? what gear ratio came stock in your car?
I have found nothing is cheap ... especially if you have to pay an installation fee
Best bang for the buck ........headers , electronic exhaust cut out , gears , 125 shot
Old Dec 1, 2013 | 10:31 AM
Affliction's Avatar
Transmission is an A4. As for the stock ratios, I am not sure.
For full roller rockers, which would I need? I hear 1.6x are good. But would they provide me more power? and would stock springs work?
Old Dec 1, 2013 | 10:53 AM
If I had it to do all over again I would do the cam , 1.6rr & springs at the same time
but the answer to your question is YES you need to change the springs....
In my opinion the best bang for the buck is what I mentioned earlier
Old Dec 1, 2013 | 11:51 AM
Check the service parts tag in the glove box or the drivers door. You will see either "GU2" (= 2.73:1) or "GU5" (=3.23:1) for your rear axle gears. That would be the gears it had when it left the factory. No guarantee that someone hasn't changed the ratio in the past 20 years.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
siguy
Nov 27, 2014 10:07 AM
