3.4 horsepower increase
what are the best mods to do to a stock automatic 94 3.4 camaro to get more power and still keep it as a daily driver
Re: 3.4 horsepower increase
I have done the follwing and from stock I felt a big difference.
K&N CAI ($289.99) Pacestter 3.4L full cat-back ($400.00 installed) J.E.T underdrive pulley ($69) Stock LT1 one piece driveshaft ($10) J.E.T. 160* thermostat ($15) I used my 93 3.4 auto as an everyday driver as well. The car was a real turd stock..this woke it up. |
or....
Magnaflow Dual Exhaust FIPK Cold Air Intake Headers, but they are expensive. Any mod is a daily driver.... |
93 LT1 you got any timeslips or know what it ran after you did all that?
I also have been looking for something to wake my slow a$$ car up...haha |
Wow, you found a driveshaft for $10!!!
Guys,
We are going back a while here. No times on my 93 3.4L but I can tell you that when I got it is was in mint shape but was a real turd. I mean slow as you can get. I seriously beleive the car was no quicker then my 91 Cavalier with the 2.2L. It is still no rocket but it does move out 10x better with that stuff then when I got it. The test vehicle was a 95 3.4L Camaro. Stock we ran a 16.3 I belive. After a pulley, CAI, 160thermo the car ran 15.9. This is WITH stock exhaust. I think my 93 is somewhere in the 15.7-8 range. The driveshaft is stock steel one from a 94 LT1. Anything more then $10 and that is considered a rip-off! |
Yea, but wouldn't aluminum be better? I didn't know upgrading to an LT1 steel driveshaft would help.
I think that any type of reduction in rotating mass helps free up HP. Did you ever hold the stock 2-piece V6 driveshaft? Heavy. Yes, the 1LE 2.75" or 3" LS1 aluminum shaft would be better than the stock LT1 shaft...but that one is way better IMO then the V6 2-piece.
The stock V6 is a 2-piece because of the lentgh of the engine. Requires a more drastic angle then the V8 version (2-pieces allows this as there is another joint). However, I have had no problems for like 40K miles with the LT1 shaft. I got mine from a local guy 5min from my house for $10. Took 10 minutes to install. |
I have a set of 35/25 swaybars for the TA so the 'Bird will get the 32/21 combo,when I do the Bilsteins the "Bird will get the 45,000 mile shocks from the TA:) |
An aluminum driveshaft is also gonna cost some money. Ive seen them go from $300-800.
(+/-)$10 driveshaft here I come! Along with TB bypass, 180* thermo, and water wetter, I'll be set.
ive got a 94 5spd
k&n cai z28 exhuast system 5.7l coil packs accel 8mm wires (instead of stock 7mm) bosche copper plugs lt1 1piece driveshaft 180 thermostat after doing all this theres a def difference in power from when it was completely stock |
I think you guys should think about this. The single most thing you can do with out making any modifications to your motor is, gears. Put a nice set of 3:73 gears in there, and your car will feel like you added a crazy amount of horsepower. Unfortunately there is not a whole lot of "bolt ons" ie: cai, exhaust, for these motors. Yes things look good on paper but by the time it gets to the the wheels..not much horsepower left. Yes weight reduction helps, but that can be costly. I heard some guys putting a nice set of flowing heads on but to really use those heads to fullest potential more bolt ons are needed. So again....look into gears.
