Does it matter what brand strut tower brace I go with?
Old Aug 20, 2006 | 08:04 PM
miaminick's Avatar
I mean, there's so many, and different prices too... is there REALLY a difference between the brands? Im thinking about even making one on my own
Old Aug 20, 2006 | 08:11 PM
Re: Does it matter what brand strut tower brace I go with?
Please post in the correct forum. This belongs in "Suspension......", not in "LT1/LT4 Engine Tech".
Moving.....
Old Aug 20, 2006 | 08:16 PM
Greed4Speed's Avatar
Just get which ever one you find the best deal on or a inexpensive used one. Wheather or not they make a diff at all is debatable but 3 point are definately worthless on 4th gens.
The 3rd point goes to the structurally weak cowl...so whats the point?
Old Aug 20, 2006 | 09:12 PM
OBE1 95Z28's Avatar
STB is for eye candy on a 4th Gen so go for looks
Old Aug 21, 2006 | 10:51 AM
Naw, STBs can be quite useful. Its a nice place to hang your microfiber towl after you dry your car.
Old Aug 21, 2006 | 03:09 PM
Dave K's Avatar
A fairly useless mod... but eye candy isn't as bad as some of the mods that have come down the pike that actually hurt performance. The worst I got suckered into was the MAF mod that did nothing other than mess up your block learn's and potentially throw a code.
Old Aug 21, 2006 | 03:31 PM
D@mn... you mean I've been driving around with this useless POS on my car for 11 years? Guess I better take it off and throw it away.....
http://www.injuneer.com/images/photo.../DCP04254a.jpg
Old Aug 21, 2006 | 06:36 PM
Severous01's Avatar
i'm with injuneer...but i wont use a 3-point brace because i've seen cracked windshields (guy didnt have subframes) at the track
it's not just eyecandy...it stops body roll in the front and is a really good place to lift the front end when you want to take the motor out the bottom.
any way, i've got one that matches the color of my car...my friend has his stripped and dipped (chrome) to match his car (teal with everything either chromed or polished) and i my other friend (sold it...so sad ) had a yellow one on his TA. we all have BMR style STB's...got mine off ebay.
Old Aug 22, 2006 | 07:52 AM
Dave K's Avatar
it wouldn't stop body roll (hopefully you've got a swaybar for that )... it would stop deflection of the shock towers (towards or away from eachother) during hard corning. The problem is that there's not a whole lot of flex in our frames in the first place, and what flex there is may be difficult to dampen out with a 2 point brace. I suppose I should take an indicator and set up an experiment to see if it really makes a difference. Jack the car on one side with stb installed and not installed and measure the amount of movement of one st relative to the other.
Old Aug 22, 2006 | 09:21 AM
JakeRobb's Avatar
Super Moderator
Seems to me that if the cowl is structurally weak, connecting it to an STB might help reduce cowl shake (generally more of a problem on convertibles).
HarleyZ28
Oct 5, 2015 06:23 AM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
