profab k member
Old Aug 19, 2006 | 12:13 AM
ith030's Avatar
profab k member
Looking at buying one of these, anyone have any trouble installing one or have trouble getting an alignment done? Will the stock a-arms, stock bolts, and motor mounts work with this piece? I have jet hot lt headers, will this k member fit? Other than quality what is the difference between this one and any one of the other tubular k members?
Old Aug 19, 2006 | 11:33 PM
Bud M's Avatar
Re: profab k member
I haven't seen the Profab K member but UMI has a new K member that looks to be a good piece for a street driven or auto x car
Old Aug 21, 2006 | 01:26 AM
crazypurgatory's Avatar
Lightbulb Re: profab k member
I have a BMR K-member and I love it.
http://www.bmrfabrication.com/
Chris G.
Old Aug 21, 2006 | 06:40 PM
Severous01's Avatar
Re: profab k member
there's a lot of positive and negative feedback from most of the aftermarket k-members...PA being the apparent worst. their welds seem to be lacking at the front lower control arm mounts...either side.
i've never seen a broken k-member, stock or aftermarket but i hear about them from shop-talk all the time...mostly the talk is of the PA k-member. i wouldnt get a new one (and i havent yet) because i see no need for it other than header clearance.
Old Aug 22, 2006 | 01:20 AM
ith030's Avatar
Re: profab k member
Thanks for the tips guys, just picked one up and it installed perfectly except 4 of the 6 stock bolts were too long so had to pick up some shorter ones.
Old Aug 22, 2006 | 02:23 AM
Question Re: profab k member
Witch one did you get?
I know you will love changing spark plugs now it will be much easier.
Plus if you get the LT4 starter it gets even a little better.
Not 100% on the starter.
Chris G.
Old Aug 22, 2006 | 07:55 AM
NOSCaMaRo's Avatar
Re: profab k member
Here are two recent post I have found with PA K-member issues, these are recent. Do a search and I am sure there are more
See post # 11- http://www.ls2.com/forums/showthread...&highlight=umi
http://web.camaross.com/forums/showt...&highlight=umi
Old Aug 22, 2006 | 09:20 AM
ith030's Avatar
Re: profab k member
Chris G.
I got the profab k member. It fit very tightly but other than that installation was very easy.
Old Aug 22, 2006 | 11:40 AM
nb 96 z's Avatar
Re: profab k member
So what's invovled with replacing the k-member yourself?
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
football4life
Oct 4, 2015 07:48 AM
KYWes
Aug 10, 2015 07:03 PM
