can I cut eibach sportline springs
Old Sep 25, 2005 | 11:50 AM
96KillaZ's Avatar
I have a 1996 z28, it has sportline springs and bilstien shocks all around. Here is my problem. My front is about a half inch higher than my rear and i want it the other way around, making my front a half inch lower than my rear. Is it ok if I cut my front springs so they drop my front about an inch? and how much shold I cut?...Thanks
Old Sep 25, 2005 | 01:29 PM
NOSCaMaRo's Avatar
Re: can I cut eibach sportline springs
I think all Eibachs sag in the rear, it sucks.
I have never heard someone cutting a Sportline, they are low as it is. Are you running a spring lsolator in the rear? If not that will take care of it. If you are I think the LS1 (if you have an LT1) lsolator is thicker and would bring the rear about a 1/2" or so.
Old Sep 25, 2005 | 03:17 PM
96KillaZ's Avatar
That sounds like a good idea. Where can I get a spring isolater?
Old Sep 25, 2005 | 05:31 PM
The alternative would be going to the QA1/HAL adjustable shocks in the front. They are threaded so the spring seat can be raised and lowered. And, add to that the Spohn coil-over rear spring/shock conversion for the rear, using the QA1/HAL's, and you can have your car at any height you want.
Generally, the heat generated in cutting a spring can destroy the temper.
Old Sep 25, 2005 | 06:14 PM
96KillaZ's Avatar
If I had the money I would, but now I'm trying to find the cheapest way to fix my rear sag.
Old Sep 25, 2005 | 10:18 PM
Z95m6's Avatar
your local suspension shop should sell aluminum spacer blocks that you can put in the rear. My shop had them ranging in 1/2" increments.
Dec 1, 2014 08:08 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
john97z28
Aug 26, 2002 04:23 PM
slothgrant
Aug 22, 2002 03:01 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
