1994 1LE Shock Valving?
Old Sep 12, 2019 | 09:09 PM
1994-LT1-Eric's Avatar
Hi,
I need to replace my shocks on the vehicle, but not sure about the springs. They're different with specific loading that came with this package. I'm trying to find close to the 1LE OEM shock replacement for the rear, which I can do myself, and also for the front. I'll have to have a shop perform the swap on the front, cause I don't have a coil over spring compressor.
I pulled this from the webs that has some details on the components of this variant where it discusses specific shock valving:
1993 brought the LT1, 6 speed and stiffer fourth gen chassis into the 1LE history. Unlike the thirdgen 1LE, the fourthgen had the same brakes as the other V8 F-bodies. The suspension was the main attraction in '93. Featuring stiffer springs at 360# linear springs up front and 130-160# progressive springs in the rear. Also included was a 21mm rear sway bar, 32mm hollow front sway bar, higher durometer control arm & panhard bushings and a solid rubber transmission mount. All '93 F-bodies with a V6 received the 275 hp LT1. Performance was the sole purpose of the 1993 1LE. These cars were sold without power accessories, T-tops or air conditioning, and aluminum drive shaft that was part of the thirdgen 1LE package is mysteriously gone in '93. Shock absorbers were DeCarbon with 1LE specific valving. 19 Camaro Z28's & only 3 Firebird Formula's were equipped with this option in 1993.
1994 & 1995 are the same as 1993 with a couple exceptions. The LT1 was converted to sequential mass air fuel injection from the batch fire speed density system used in 1993 and the rear sway bar was reduced to the 19mm bar used on all V8 F-bodies. 1995 cars sold in California were equipped with dual cats and power increased to 285 hp. In 1994 135 Camaro Z28's and no Firebird 1LE's are built! In 1995 106 Camaro Z28's and 2 Firebird 1LE's are built.
With 360# linear springs in the front and 160# in the rear I'm not sure what would be a similar replacement shock for the 1LE.
Old Sep 12, 2019 | 09:17 PM
Re: 1994 1LE Shock Valving?
I found this also from back in 2005
Originally Posted by OBE1 95Z28
Here's a great write-up from the F-Body.org FAQ section:
Q: What's included in the 1LE performance package??
A: The package required these options (Z28/Formula, respectively):
Basic option group (FZAB/1SA)
A/C delete (until 1996 when A/C became standard)
6-speed tranny or performance rear axle with the automatic (GU5/G92)
Z-rated tires w/ 150 speedo (QLC/QLC)
Base stereo
and it consisted of:
Higher rate front springs (360 lbs/in for mid-1994 and after)
Variable rate rear springs (130-180 lbs/in for mid-1994 and after)
Stiffer front and rear shocks (Koni double adjustable for 1996 and after)
Harder bushings (front upper/lower and rear control arms)
Larger diameter anti-sway bars (32mm front, 21mm/19mm rear)
Increased cooling (for 1995 and after)
Engine oil cooler (1993 - 1995)
The 1993 1LE cars had the same springs and deCarbon shocks (but with much stiffer valving) as on the stock Z28s and Formulas. Initial 1994 1LE cars received the same set-up, but sometime during model year (between Dec 94 and Mar 95), the 1LEs received stiffer (higher/variable rate) springs and the shock valving was slightly reduced (but still considerably stiffer than the stock deCarbon valving). Due to the stiffer springs and modified valving, the 21mm rear sway bar was dropped in favor of the 19mm bar (which was the same as on the stock Z28s and Formulas). In 1996, the Koni double adjustable shocks became standard on the 1LE cars. Increased cooling on 1995 and after models was accomplished by the addition of an air conditioning radiator baffle even though no AC was available in 1995. Also, after 1995, in order to get the 1LE on the Firebird or Trans Am you had to order the WS6 package.
Here's a list of suspension parts and prices for 1994 models:
Part No. Description Wholsale / List Price
22145653 Left front upper control arm $109.50 $146.00
22145654 Right front upper control arm $109.50 $146.00
22145389 Left front lower control arm $111.75 $149.00
22156436 Right front lower control arm $111.75 $149.00
26032907 Front stabilizer bar $67.37 $89.70
26039956 Stabilizer bar insulator (2) $7.20 $10.00
10262147 Rear axle tie rod $33.94 $45.25
10164151 Rear lower control arm (2) $49.31 $65.75
10021221 Rear stabilizer bar $45.94 $61.25
22124790 Rear shock absorber (2) $57.75 $77.00
22132561 Front springs (2) $80.00 $100+
22132562 Rear springs (2) $80.00 $100+
Old Sep 12, 2019 | 09:26 PM
Ask Sam Strano.... if anyone knows, he will.
Strano Performance Parts - Parts Catalog
Old Sep 12, 2019 | 09:50 PM
Ok, sent them an email. Thank you.
I also contacted Bilstein to see what they're recommendations would be on that spring loading.
pattracing212
Mar 26, 2007 11:20 PM
JohnD
Jun 22, 2005 10:36 PM
raiderman119
Apr 19, 2005 10:57 AM
Bow94z
Dec 5, 2004 11:05 PM
94Zman
Dec 1, 2002 09:47 AM
