1le
Old Mar 26, 2007 | 08:07 PM
pattracing212's Avatar
1le
this is probably gonna sound like a newbie question but i always hear people talking about the 1le stuff for the camaro. what is it?
Old Mar 26, 2007 | 09:39 PM
so no one knows anyting aabout 1le
Old Mar 26, 2007 | 09:46 PM
ACE1252's Avatar
Q: What's included in the 1LE performance package?
A: The package required these options (Z28/Formula, respectively):
* Basic option group (FZAB/1SA)
* A/C delete (until 1996 when A/C became standard)
* 6-speed transmission or performance rear axle with the automatic (GU5/G92)
* Z-rated tires w/ 150 speedo (QLC/QLC)
* Base stereo
and it consisted of:
* Higher rate front springs (360 lbs/in for mid-1994 and after)
* Variable rate rear springs (130-180 lbs/in for mid-1994 and after)
* Stiffer front and rear shocks (Koni double adjustable for 1996 and after)
* Harder bushings (front upper/lower and rear control arms)
* Larger diameter anti-sway bars (32mm front, 21mm/19mm rear)
* Increased cooling (for 1995 and after)
* Engine oil cooler (1993 - 1995)
* Stronger Transmission mount for 6 speed Transmission's
* Stiffer Panhard-bar bushings
The 1993 1LE cars had the same springs and deCarbon shocks (but with much stiffer valving) as on the stock Z28s and Formulas. Initial 1994 1LE cars received the same set-up, but sometime during model year (between Dec 94 and Mar 95), the 1LEs received stiffer (higher/variable rate) springs and the shock valving was slightly reduced (but still considerably stiffer than the stock deCarbon valving). Due to the stiffer springs and modified valving, the 21mm rear sway bar was dropped in favor of the 19mm bar (which was the same as on the stock Z28s and Formulas). In 1996, the Koni double adjustable shocks became standard on the 1LE cars. Increased cooling on 1995 and after models was accomplished by the addition of an air conditioning radiator baffle even though no AC was available in 1995. Also, after 1995, in order to get the 1LE on the Firebird or Trans Am you had to order the WS6 package. According to the 1997 Pontiac brochure, the 1LE package could not be ordered with the automatic transmission.
Here's a list of suspension parts and prices for 1994 models:
Part No. Description Wholesale / List Price
22145653 Left front upper control arm $109.50 $146.00
22145654 Right front upper control arm $109.50 $146.00
22145389 Left front lower control arm $111.75 $149.00
22156436 Right front lower control arm $111.75 $149.00
26032907 Front stabilizer bar $67.37 $89.70
26039956 Stabilizer bar insulator (2) $7.20 $10.00
10262147 Rear axle tie rod $33.94 $45.25
10164151 Rear lower control arm (2) $49.31 $65.75
10021221 Rear stabilizer bar $45.94 $61.25
22124790 Rear shock absorber (2) $57.75 $77.00
22132561 Front springs (2) $80.00 $100+
22132562 Rear springs (2) $80.00 $100+
The Lou Fusz automotive network of dealers have items at the wholesale price.
I got the info at this link under general information. This is the 4th-gen FAQ.
http://www.f-body.org/faq/4/index.htm
Old Mar 26, 2007 | 09:54 PM
thanks for the info....but is there a vin code to know if your car had it....i have most of the stuff that is on that list but not all of it.
Old Mar 26, 2007 | 10:08 PM
ACE1252's Avatar
To know if your car has the option, look on the inside of your drivers door(there is an options label there) and look for the "1LE" option code. You will also notice the "Z28" code there too for your Z.
Old Mar 26, 2007 | 11:20 PM
You won't find your RPO (Regular Prodution Option) code sticker on the driver's door on a 1994. It's in the glove box. 1LE is an RPO code.
Kinglouui
May 26, 2016 11:05 AM
force10
Jul 30, 2015 04:56 PM
Jlo
Jul 29, 2015 03:52 PM
SpeedJunkee
Jul 19, 2015 09:06 PM
gto4u2
Mar 14, 2015 06:05 AM
