1LE swaybar
1LE swaybar
I installed my 1LE rear swaybar last weekend and the difference is amazing. The car feels like it's on rails. After the subframe install, esp., the 1LE springs and the Z rated tires you can feel every piece of gravel in the road-which is ok, I like that.
Re: 1LE swaybar
Is that the rear 1LE bar?
I have the 1LE rear swaybar with poly bushings and it made a nice improvement. It kept the rear end from having that waggy feeling. They HUGE improvement was the 35mm solid front bar. Oh man, what a great mod.
Dan
Dan
Re: 1LE swaybar
That's going to be a rough riding Z28 if you put stiffer springs, and a stiffer swaybar on there. Mine already rides stiff enough and it has stock springs up front with Bilstein HD shocks and the 35mm front sway bar. It's not too stiff though, but any more would be too excessive for me.
You don't need to touch the shocks or springs to install the front swaybar remember.
Dan
Dan
Re: 1LE swaybar
Dan
Dan
david
Re: 1LE swaybar
Originally Posted by dren70
dont mean to hijack the thread sorry. dan can you email me and tell me how you got the spindle / hub assembly off the knuckle when you did the c5 brakes?? thanks.
david
david
Dan
