Autocross and Road Racing Technique There is more to life than a straight line
1LE suspension spring specs?
Old Nov 22, 2002 | 11:07 PM
94Zman's Avatar
Thumbs up 1LE suspension spring specs?
Can anyone confirm the specs for the 1LE springs over the stock springs? Looking for a firmer ride but not a big drop in ride height
Thanks!
Old Nov 24, 2002 | 11:25 PM
BobC's Avatar
yes, they are a good bit stiffer and won't lower the car. you should be able to find a set for $100
Old Nov 25, 2002 | 12:58 AM
2002Z28SSConv's Avatar
I just found this link in another post a little while ago. It's got some good info in it.
http://angelfire.com/my/fastcar/suspension.html
Old Nov 25, 2002 | 12:16 PM
Sam Strano's Avatar
Front: 360 lbs./in
Rear: '93 stock Z28 (approx. 115) with 21mm rear bar
'94+ 130-180 variable with 19mm rear bar
Old Nov 26, 2002 | 12:47 AM
94Zman's Avatar
Thanks guys, this is great info.
Old Dec 1, 2002 | 09:47 AM
SDA's Avatar
SDA
1LE front springs #22132887 from gmpartsdirect.com
$97.11 pair delivered.
HarleyZ28
Oct 5, 2015 06:23 AM
blkWidow
Sep 6, 2015 05:17 PM
R@mpage
Apr 20, 2015 10:02 AM
blkWidow
Apr 20, 2015 09:27 AM
PublicEnemy1
Apr 7, 2015 12:21 PM
