cooling fan wiring help!
Old 01-21-2019, 01:27 AM
racer96's Avatar
hey all. i am going to be running the mighty mouse fan harness. it has its own relays on the harness. i was wondering if i can take the signals off the harness by the computer. red connecter 10 and 11? Also i am cleaning up my engine bay and lookig at removing wires and relocating the fuse box under the hood. can i terminate the cooling fan relays in the fuse box since i will be running the new harness or do they still need to be there? also fuse number 7 is a a/p, fan fuse but im sure that fuse does more then just the fan or can that go as well? thanks
racer96 is offline
Old 01-21-2019, 09:22 AM
shoebox's Avatar
Re: cooling fan wiring help!
You should be ok to use 10 and 11 to trigger your fans. You can remove the fan relays in the factory fuse block. Fuse #7 powers the fan relays and the AIR pump. If you have no pump, you can eliminate that fuse. Your MM fan harness has it's own power supply leads.
shoebox is offline
Old 01-21-2019, 10:02 AM
racer96's Avatar
Ok great! I read somewhere fuse 7 did more then that. But good to know. I also have my abs, air pump, horn, cruise control and ac deleted off the car. So basically the only things in that fuse box I need are the fog light relay, actuators,injectors,engine sensors, and ignition?
going to be buying a smaller fuse box and installing it in the glove box. The stock one won’t fit through the fire wall so going to have to remove wires anyways. Thanks
racer96 is offline
Old 01-21-2019, 04:31 PM
racer96's Avatar
I guess I should say it’s a 96 Camaro z28
racer96 is offline
Old 01-22-2019, 02:56 PM
Free download of 1996 factory service manual courtesy of GaryDoug:
http://www.mediafire.com/?40mfgeoe4ctti
Injuneer is offline
userchemical
06-15-2009 05:46 PM
gpss97
02-13-2008 05:03 PM
xxxtreme36
09-10-2007 05:41 PM
wiked95ta
08-09-2005 09:36 AM
phrozen
09-19-2004 06:14 PM
Quick Reply: cooling fan wiring help!
