Fan fuse blowing.......HELP
Old Sep 9, 2007 | 06:58 PM
xxxtreme36's Avatar
Went for a drive and the car started to heat up when i was sitting at a light, was fine when moving. Got home and realized the fans werent turning on. So i look at the fuses and the fan fuse is shot, and the wire to the block thats running my electric waterpump is burnt looking towards the fuse block.. So i replace the fan fuse and turn them on, they come on and then the wire harness on the pass. side with the starter wires i believe starts to smoke, so obviously i kill it.
I need some help.....kinda lost whether one caused the other, i washed the car today if that means anything. I do not have the air pump so no worries there.
Old Sep 9, 2007 | 07:05 PM
dangalla's Avatar
look very closely where the harness was smoking, there has to be some shorted wires there
Old Sep 9, 2007 | 09:12 PM
1997blackz28's Avatar
yep something is shorted causing your fuse to blow.
Old Sep 9, 2007 | 10:34 PM
BMoney's Avatar
hey give me a call tomorrow, maybe I can come over and give you a hand.
Brian
Old Sep 9, 2007 | 10:36 PM
CamaroZ2869C's Avatar
im having the same problem. my fan fuse under hood is blowing. my electric water pump is tied into the ignition fuse nothing off of the fan fuse. a 25 wont blow but gets hot and so does the brown wire coming from that fuse location. the voltage from the alternator drops to lik 9 with a fuse in.
Old Sep 10, 2007 | 08:30 AM
xxxtreme36's Avatar
well the only issue with it being shorted is that when i first got the car running i ran through my stock ignition instead of the msd box, but make sure it started. Then after i hooked up the msd box yesterday is when it started the fuse blowing and what not.........
Ill get at ya B
Old Sep 10, 2007 | 08:40 AM
What did you hook the MSD up to for +12V?
Old Sep 10, 2007 | 12:01 PM
xxxtreme36's Avatar
i believe its to the battery, or the extra battery terminal right next to it. The msd box came with the car. But i just ran it for a bit without using the msd and everything seemed ok other than the damn tire blew and my supercharger belt ripped from a bent pulley...
Old Sep 10, 2007 | 04:10 PM
And when your S/C belt let loose, did it hit any of the wiring?
Old Sep 10, 2007 | 05:41 PM
xxxtreme36's Avatar
well this issue was before i had the belt on...........
jerrysims71
Aug 15, 2015 12:47 PM
4586
Aug 2, 2015 01:45 PM
RUNMYTA
Jul 15, 2015 07:50 PM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
