WOT and WINDOW switches?!
Old Oct 28, 2004 | 12:59 AM
1995CamaroZ28's Avatar
Do i really need them both on - NX 100 shot.
All I have is the WOT switch, and i'm going to get a WINDOW SWITCH..
so my question is if i'm getting the window switch, do i still need to get the TPS one?
thanks
Old Oct 28, 2004 | 04:23 AM
sssalah's Avatar
Re: WOT and WINDOW switches?!
Its better to have them both. You dont' woant your system activate unless your tb blades are fully open. A window switch is nice to have since you want activation not to be at low rpm which could cause backfire (this is not going to happen in your case with the 2800 stall) and you don't wan't it ot be sprying through the shifts, or hit the limiter.
Old Oct 28, 2004 | 10:20 AM
isn't the WOT and the TPS switches are the same?!??
why do i need a tps switch?
Old Oct 28, 2004 | 11:04 AM
so, this is all i really need: ?!
-rpm window switch
-fuel pressure switch
-wot switch
-colder plugs
NO need for TPS switch..
thanks
Old Oct 28, 2004 | 02:14 PM
Mr_Bond's Avatar
The tps switch makes for a cleaner install. With the NX one you just tap your pcm's tps wire and at 4.0 volt is on. I've seen other that just plug into the tsp it's self.
Old Oct 28, 2004 | 03:46 PM
so, i don't really need the TPS switch as for a safety issue.?
do i need anything else, besides what i have listed above?!
Old Oct 29, 2004 | 02:29 AM
94ZRiCeKiLr's Avatar
no, as long as you have a WOT switch instead, you're good to go.
Old Oct 29, 2004 | 08:46 AM
ford's Avatar
-rpm window switch
-wot switch
-colder plugs
thanks
I used a mallory 685 CD ingnition box, as it had the rpm window switch and was able to pull timing out for my 150shot. A 100 shot isnt much but an ignition box wouldnt hurt i think.
MDZ28
11
Sep 24, 2015 09:15 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
z28cam1993
Sep 9, 2015 04:08 AM
Jlo
Jul 29, 2015 03:52 PM
Jul 10, 2015 02:23 PM
