Blow down tube installation?
Alright I understand why you woudl have a blow down tube.
My question is how do you install it? Do you just unscrew this cap(see pic) and screw the tube on and have it lead out the car somehow?
http://www.porteightyhosting.com/uploads/IMG_0037.JPG
Jsut making sure it is right and I don't just empty the bottle by doing the wrong thing
Re: Blow down tube installation?
Yes, this is removed and below it is a rupture disc that is discarded. Use a new rupture disc (should come with the tube) and tight the disc down with a good torque wrench to the specified value. This will ensure that the disc gets ruptured at the design rupture pressure.
Yes, if you remove that fitting with the bottle full, all the nitrous will come out. You need to purchase another fitting that's specifically made to hook a blow-down tube to, and unfortunately your bottle will need to be empty when you hook up this fitting. I can't remember a name or part number for it - it'll be a standard NOS part.
Dave
Dave
The NOS fitting that screws onto the male threads under the blowoff diffuser cap in the picture is P/N 16170. Includes the adapter fitting, a new rupture disc, and a new diffuser cap on a tether that helps prevent the bottle from spinning wildly, should the disc rupture while the bottle is being transported loose.
You can also attach an -8AN braided hose to the new fitting, if that's how you want to vent the system, rather than using the rigid blowdown tube.
http://cjcfo.fbody.com/members/injun.../DCP03655a.jpg
Alright guys thanks, this all kind of was in the back of my head but I wasn't sure, woudl have been a surprise when I go to open the valve and emptied a full bottle in front of my self
Richardan15
May 30, 2015 08:36 AM
