WOT and WINDOW switches?!
Do i really need them both on - NX 100 shot.
All I have is the WOT switch, and i'm going to get a WINDOW SWITCH..
so my question is if i'm getting the window switch, do i still need to get the TPS one?
thanks
thanks
Re: WOT and WINDOW switches?!
Its better to have them both. You dont' woant your system activate unless your tb blades are fully open. A window switch is nice to have since you want activation not to be at low rpm which could cause backfire (this is not going to happen in your case with the 2800 stall) and you don't wan't it ot be sprying through the shifts, or hit the limiter.
The tps switch makes for a cleaner install. With the NX one you just tap your pcm's tps wire and at 4.0 volt is on. I've seen other that just plug into the tsp it's self.
Originally Posted by 1995CamaroZ28
so, i don't really need the TPS switch as for a safety issue.?
do i need anything else, besides what i have listed above?!
so, this is all i really need: ?!
-rpm window switch
-fuel pressure switch
-wot switch
-colder plugs
NO need for TPS switch..
thanks
-rpm window switch
-wot switch
-colder plugs
thanks
z28cam1993
Sep 9, 2015 04:08 AM
Jul 10, 2015 02:23 PM
