125 shot on 305
Old May 6, 2003 | 08:27 AM
92_RS_305's Avatar
125 shot on 305
What kind of mods will I need to be able to run a 125 shot on my 305 without messing anything up?
Old May 6, 2003 | 05:17 PM
COMNBYU's Avatar
You don't need any mods. If you want to play it safe (and you DO, trust me ) I would at least get FPSS, WOTS, proper gauges, and possibly one step colder plugs. This is of course assuming you're using a WET kit, which I would recomend.
I probably wouldn't go over a 125 on your motor. The motor should take it fine and you shouldn't have any problems as long as the fuel pressure is there. However, be prepared to freshen it up or do a minor rebuild down the road.
Technically, as I said in the first paragraph, you don't HAVE to have any mods or saftey nets- I'm a perfect example of that. I ran a 150 shot on my LT1 with absolutley no mods for a while. Luckily I had no problems, but others have.
Jon
Old May 6, 2003 | 07:00 PM
Chuck!'s Avatar
Do some searches for posts by AutoRoc, he ran a 100 shot on a stock bottom 305 with great results, and now he's got a 150 on the same bottom end.
LT14LIFE
Nov 15, 2015 06:22 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
