Zinc cam oil
Old Sep 22, 2008 | 07:42 AM
95ltslow's Avatar
Zinc cam oil
Since i had my cam installed on my 95 lt1 my friend keeps telling me (actually annoying the hell out of me) that i should be using some type of special oil or use and additive(sp?) that has zinc in it. I searched around a little and didnt find much. Anyone know what oil to use? The cam i have is a CC502
Old Sep 22, 2008 | 09:56 AM
kylersaulsbury's Avatar
no not for hydraulic cams only flat tappet (and maybe solid roller).
Old Sep 22, 2008 | 06:22 PM
Zaknafein's Avatar
Zinc is a great high pressure lubricant... the problem is, it causes problems for 02 sensors, hence a lot of zinc levels have been reduced.
I personally wouldn't recommend a zinc additive. You should be fine as long as the cam was installed properly (adequate assembly lube).
Old Sep 22, 2008 | 08:44 PM
96capricemgr's Avatar
As said by the first person to reply. This is a concern for flat tappet cams, not the hydraulic roller you used.
rideordie
Nov 5, 2019 04:52 PM
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Queens94z28
Dec 20, 2014 09:11 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
