Voltage drops by 50% around 4K at WOT?
Old Sep 20, 2008 | 08:17 AM
trax's Avatar
Hi guys,
I've been on business trips lately, but I finally got home to enjoy the car again this past week. I took it out for a few evening drives, and I noticed a problem--when I go WOT, the voltage will dip to around 50% somewhere past 4K, and it will dip so bad that the engine misfires. The car has around 65K miles on it, still has the original factory alternator and tensioner.
My list of stuff to check is:
  1. Verify that there's 13+ volts coming out of the alternator at idle
  2. Check for corrosion at battery and grounding terminals
  3. Take alternator to AutoZone / Advance, have them test it
  4. Check belt tensioner to see if it's going bad
How does that sound?
Old Sep 20, 2008 | 11:06 AM
mrmint69's Avatar
I would clean the conections and then go have it tested.
Old Sep 20, 2008 | 01:40 PM
87bandit's Avatar
I had an alternator bracket bolt back out and car was losing alot of voltage due to belt slip/skip
I'd say alternator is the likely suspect imo
Old Sep 20, 2008 | 03:12 PM
n2ceptor's Avatar
Belt slip..IMO..
Old Sep 22, 2008 | 06:07 PM
klrz28's Avatar
Check your grounds also...
Old Sep 22, 2008 | 09:29 PM
mrmint69's Avatar
I checked my alternator this weekend and the back bolt on the top was gone. It didn't cause any problems but could if more than one was gone or the right one.
Chet1185
Jul 20, 2016 06:09 AM
PopoFormula
Oct 12, 2015 04:19 PM
DelSoto
Sep 19, 2015 05:31 AM
mmf_1013
Sep 12, 2015 08:56 PM
tdigger9899
Sep 7, 2015 10:56 AM
