For you people who want/need an LT4 Intake Manifold
Old Feb 4, 2006 | 12:28 PM
  #31
marshall93z's Avatar
Re: For you people who want/need an LT4 Intake Manifold
Wow!! That's hard to believe for just the intake work!
Old Feb 4, 2006 | 12:45 PM
  #32
TQdrivenws6's Avatar
JUST the manifold is under 1000. Then you need a $215 elbow and $280 tb etc. I have about 2300 into mine, but thats also with 600 worth of cam/valvetrain, 200 for porting, $135 carbon fibre base etc etc etc.
Old Feb 4, 2006 | 01:02 PM
  #33
Fastbird93's Avatar
How much was the work on the manifold?? THe fuel line drilling/plumbing, map sensor hole fabrication, ect.
What about an IAC function?? Will this give you that ability or are you just going to have to play with the blades?
Old Feb 5, 2006 | 12:44 AM
  #34
tritonium's Avatar
IF this thing never comes out...
Is it possible to moddify a stock LT1 intake manifold to accept the different angel of an AFR head? i beleive is is 7 segrees different? is there enough "meat" on the stock one to mod it? thanks
Old Feb 5, 2006 | 11:13 AM
  #35
Fastbird93's Avatar
With welding it's doable. Been done many times before actually.
Old Feb 5, 2006 | 11:50 AM
  #36
tritonium's Avatar
Anyidea on a rough cost to have this done?
Old Feb 5, 2006 | 01:23 PM
  #37
LT1 EXPRESS's Avatar
That's a really good thought, but you're talking in the area of about $1500 or so for just the manifold (including plumbing for injector rails, MAP, ect). Then you have to add in an elbow, different TB, reworked throttle cables, electrical wiring. It adds up rather quickly. I've talked to a couple of guys who've said that they've got $2K+ into it once complete.
Granted, it's going to offer ya a bit more power, but still......dang.
In the process of doing that now thats why I am selling my lt4 intake with the direct port fogger I have over 1200 in the manifold plus my rails accufab t body will have close to 2000 invested when done
Old Feb 5, 2006 | 01:27 PM
  #38
I am runing a accufab ford t body with Iac have an addapter to run a gm iac on the ford t body.My custom intake elbow hat will have a vacum line for fuel reg and map sensor.
Old Feb 5, 2006 | 01:29 PM
  #39
All these prices are high on ebay I am thinking about just selling my intake on there seeing what I can get got to bring home some good money.Heres some pics if anyone is intrested http://members14.clubphoto.com/micha...48/guest.phtml
Old Feb 5, 2006 | 06:15 PM
  #40
tritonium's Avatar
If you leave the fuel rails and injectors i say u could easily get over 1500 for that.
Old Feb 5, 2006 | 11:25 PM
  #41
EVREYTHING INCLUDED BUT THE INJECTORS AND MAP
Old Feb 5, 2006 | 11:28 PM
  #42
Let's not turn this into a "parts for sale" thread, or it will be moved off of LT1/LT4 Engine Tech.
Old Feb 12, 2006 | 07:41 PM
  #43
ttrimz208's Avatar
Have any of you seen this? http://www.z28.com/forum/showthread.php?t=59665
Now maybe people will stop buying $1500 LT4 intakes.
Old Feb 12, 2006 | 07:46 PM
  #44
Fastbird93's Avatar
Like I said, edlebrock has one on the way out.
*Edit* Just found it. Scroll down to page 59. Part numbers 7107 for the LT1 and 7109 for the LT4.
http://www.edelbrock.com/automotive_...manifolds).pdf
I like the air-gap idea and their attention to detail shows because if you notice, there are still IAC and PCV Ports.
Old Feb 12, 2006 | 08:03 PM
  #45
Zepher's Avatar
Wow, I should have held onto my LT4 setup.
I got the LT4 heads and intake from a member here for $900 shipped and the LT4 hotcam $180.
