will triangular subframe connectors work with hooker longtubes?
Old Jan 12, 2004 | 09:34 PM
wayne97's Avatar
I have hooker longtubes with a mufflex y-pipe - will traingular subframe connectors work alright with this setup? Does anyone have any experience with this at all? If it wont work , what should I look into. Thanks!
Old Jan 12, 2004 | 11:09 PM
revtime's Avatar
A Ypipe should fit ok with DD SFCs, Straight pipes are a little harder to fit, I have purple hornies on my LTs but I had to shorten them a bit to clear the DDs.
Your tranny crossmember will probably give you more problems than the SFCs.
Old Jan 12, 2004 | 11:42 PM
engineermike's Avatar
Kenny Brown DD's work fine with Hooker LT's/Mufflex Y-pipe. The Y-pipe interferes with everything else under the car, though.
Mike
Achilles97
Sep 13, 2002 10:49 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Jibberish18
Aug 28, 2002 12:46 PM
slothgrant
Aug 22, 2002 03:01 PM
