will triangular subframe connectors work with hooker longtubes?
I have hooker longtubes with a mufflex y-pipe - will traingular subframe connectors work alright with this setup? Does anyone have any experience with this at all? If it wont work , what should I look into. Thanks!
A Ypipe should fit ok with DD SFCs, Straight pipes are a little harder to fit, I have purple hornies on my LTs but I had to shorten them a bit to clear the DDs.
Your tranny crossmember will probably give you more problems than the SFCs.
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Jibberish18
Aug 28, 2002 12:46 PM
slothgrant
Aug 22, 2002 03:01 PM
