wierd problem
Old Nov 27, 2006 | 04:28 PM
diamondhill's Avatar
wierd problem
well i started my day normal drove my car to work and it to was running normal. every day i take out my injector fuses under the hood so it would be harder for some one to steal my car, any ways it started to raining lightly well i open the hood to re install the fuses and get in the car to start and it started right up ,only now it has a wierd miss fire so i pull over at the gas station to double check the fuses and every thing is correct.
so i start up the car and no change its misfiring and running rough ,and the engine is shaking, but i dont have an SES light on. by now its stopped raining so i decide to get on the gas and at first it would hesitate and wouldnt accellerate but then it all of a sudden drives normal again???? what was it causing the problem? i have new opti less then 1k on it new plugs , and wires what could it be
Old Nov 27, 2006 | 04:36 PM
Would be helpful to know the year of the car and any major mods. Whether you get an SES light for a misfire depends on the year, for example.
Old Nov 27, 2006 | 04:41 PM
sorry its a 95 trans am obd 1 and no major mods new fuel pump 155 lph ,cats deleted, lt1 engine
Old Nov 27, 2006 | 08:30 PM
OBE1 95Z28's Avatar
If you have CAI, a wet air filter will cause the car to stumble until the filter dries out.
Old Nov 28, 2006 | 06:16 AM
no i dont have a CAI .
Old Nov 28, 2006 | 10:02 AM
1racerdude's Avatar
Opti or plug wires.
They'll do that when they get wet and leaking.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
Hot Rod Hawk
Aug 15, 2002 10:47 PM
formula79
Jul 13, 2002 09:06 PM
