I need to lower the compression of my lt1
Old Nov 27, 2006 | 10:15 PM
SmokinZ28lt1's Avatar
Question I need to lower the compression of my lt1
I Just bought a brand new sts turbo system for my 94 camaro and I can set the turbo from 5-15 psi but I know a stock lt1 can't handle much more boost than 7-8psi because of the high compression of the lt1. So if there is a way to lower my compression or something I'm pretty shure I can retard the timing with the Nelson Performance PCM tuner I got but I dont know how slow I can set it without my engine running like crap I would like to get it down to 9:1 it so I can run like 12-13 pounds or more of boost because my turbo can support up to 900 hp but I only wanna run 600hp for now which i should get a 12 psi
If I put heads with 76cc combustion chambers would that lower the comperssion? and I don't know much about pistons so where should I get them and what ones should I use to lower my compresion? and would I need a diffrent crank cause I'm going to be runnin about 600 hp and the stock crank is only good to like 450 isn't it?and how much can my stock six speed handle? and what would be a good cam to run with this engine but I can't figure out what one or brand to buy so if you could help me out it would be much appriciated
Old Nov 28, 2006 | 12:13 AM
SS RRR's Avatar
Start conducting lots of searches and do lots of reading here:
http://web.camaross.com/forums/forumdisplay.php?f=10
Old Nov 28, 2006 | 08:27 AM
WS Sick's Avatar
Yeah a larger chamber will lower the compression, but it won't strengthen the pistons. (especially against 15 #s of boost)
Old Nov 28, 2006 | 10:23 AM
Generally a good idea to keep all the posts in one thread.......
http://camaross.com/forums/showthread.php?t=486925
Your earlier post was moved because it belonged on the "Forced Induction" forum.
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Jan 31, 2015 07:29 PM
Jason Short
Jan 19, 2015 06:34 PM
thenewkid
Nov 27, 2014 09:41 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
