what pushrod do i need?
Self-aligning or NSA rockers? Length will be determined by using a pushrod length checker. What lifters? No one can tell you what pushrods to use without that info.
Moving to LT1 Based Engine Tech.....
By "type" I am assuming you mean general categories, not length. You will need to measure to get the correct length. You would need hardened PR if you are using guide plates. If you are using self aligning rockers, with the little "****" on either side of the roller tip, you do not need hardened PR. As far as diameter, wall thickness, quality, etc. this will depend primarily on spring pressure. What are your spring specs?
Rich
Rich
