what pushrod do i need?
Old Jun 4, 2009 | 07:46 AM
lt170chevelle's Avatar
Ok got me a custom turbo cam coming and need to know what pushrods to order? just hardened stockers? its 540-560ish lift. and have matching springs.
Old Jun 4, 2009 | 05:25 PM
Self-aligning or NSA rockers? Length will be determined by using a pushrod length checker. What lifters? No one can tell you what pushrods to use without that info.
Moving to LT1 Based Engine Tech.....
Old Jun 4, 2009 | 08:06 PM
Hal Fisher's Avatar
Have you got pushrods in now? If you do no need to change for a turbo or supercharger. If anything needs to be done to accommodate a turbo it's changing the pistons.
Hal
Old Jun 5, 2009 | 10:24 AM
rskrause's Avatar
Moderator
By "type" I am assuming you mean general categories, not length. You will need to measure to get the correct length. You would need hardened PR if you are using guide plates. If you are using self aligning rockers, with the little "****" on either side of the roller tip, you do not need hardened PR. As far as diameter, wall thickness, quality, etc. this will depend primarily on spring pressure. What are your spring specs?
Rich
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
94Form
Jul 17, 2015 10:56 PM
