What fuel pump to buy.
Old Aug 7, 2003 | 11:14 PM
  #16
AlexsZ's Avatar
I recently bought the Walboro 255lph in tank pump from musclemotors.com for about $125. Easy change, and I did it from the top by cutting the whole, and I had a full tank of gas. Just get a floor fan blowing hard, use a dremel or a battery powered cutting saw and go at it.
Valid arguments for and against...its your call, but I prefer this way since in the future all I have to do is remove 8 screws and I can change it in 20 minutes vice 2+ hours.
Old Aug 8, 2003 | 01:13 AM
  #17
Transamdriver's Avatar
I just installed my Racetronix system by cutting the hole, only took me about 2hrs total to do the install.
Old Aug 8, 2003 | 01:46 AM
  #18
revtime's Avatar
Yes there are valid arguements for and against.
I changed my window motor by drilling holes in my door, (GASP) I drilled holes in my car!!!!
Get over it. Its your car so you be the judge on what you want to do: 2, 3 or more hours pulling the tank or 1 or 2 hours cutting a hole that no one is going to see so it makes things easier.
GM should have made this access hole to begin with so I have no problem making my life a little easier.
Its your car though so your decision is final and what really counts here.
Good Luck.
Just for the record, I paid someone else to change the fuel pump in my 88 IROC cause I did not have a place to do it myself and I have vowed never to pay someone 500 bucks to do something I can do in 20 minutes after the access hole is there.
Old Aug 8, 2003 | 05:51 AM
  #19
funina91ss's Avatar
If you want to be "SAFE" about it, use tin snips instead of the dremail, its alot faster and safer. I did mine in less than 30 min., that's with cutting the whole and installing the pump. I used a 1/2" drill bit to make the first whole and tin sniped the rest out, real clean and no sparks at all. I Used a pice of metal off a old hood I had at work and some sheet metal screws with some seamsealer under it.
Good Luck Sean
Old Aug 8, 2003 | 10:54 AM
  #20
Professor Booty's Avatar
Well I have a couple weeks before I'm going to do it so I'll think about it. I certainly don't want to pay $500 to have a $150 part installed. Thanks for all the input guys.
Old Aug 9, 2003 | 04:10 AM
  #21
Racetronix's Avatar
The BBK, Grant, Holley and Racetronix pumps are all made by Walbro.
The difference is that Racetronix modifies the pump specifically in order to be as close to a true factory LT1 replacement. Special hardware is supplied to make it as PnP as possible.
For more info please see this thread:
http://web.camaross.com/forums/showt...threadid=66289
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
