Valve spring seats ?
Old Aug 8, 2003 | 08:12 PM
BAD97SS's Avatar
I have the competition cams valve spring cca-986 dual springs. Just wondering what seats everyone is using. Any help would be great.
Old Aug 9, 2003 | 04:15 AM
NightTrain66's Avatar
Comp 4771's are what most people use. They do require a lil grinding or cylinder head machining to fit. Most people grind the locator. It takes a few seconds and can be done with a bench grinder. You only need to grind an 1/8 inch "indention" in each one and then clearance the 2 on the center exhaust ports for head bolt/washer clearance.
Comp 4770's will not need any grinding/machining but they are a larger ID and will not fit as tight on the guides. This kinda defeats the purpose of using "locators".
Crane makes some (and I am sure other manufacturers do as well) that will work but not sure if they need grinding/machining as well.
NightTrain66
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
