Went to the track with new setup (is this right)?
Old Aug 1, 2004 | 05:08 PM
Ryan94Camaro's Avatar
I just got doing a rebuild to my LT1. In the 1/8 mile when it was stock it ran 9.4. I put an eagle 355 rotating assy. in it. Pocket ported the heads a very little bit myself, Milled the heads, comp pro mag 1.6 rockers, 918 springs (ls1 valve spring setup), xe230/236 .544/.555 112 cam, stock tranny (slipping and hitting the rev limiter on 1-2 and 2-3 shifts) , Slp 2800 converter, 3.43 gears. 30lb SVO injectors.
I was running stock bald street tires at 32 psi and not spinning one bit. Here are my new times:
2.027 60 ft
8.569 1/8mi
83.37 mph
It was 95 degrees out, 70% humidity, 400ft above sea level.
The main thing I am worried about is its not shifting right even after the dyno tune. However I put new gears in since then. 3.43 from 2.73
I think with the shifting fixed and at night it would run a 8.2
Are my times on par with what they should be.
Old Aug 1, 2004 | 11:30 PM
madwolf's Avatar
Re: Went to the track with new setup (is this right)?
How much power/torque did it put down? What RPM did it shift at the track?
Old Aug 2, 2004 | 12:10 AM
jchevy's Avatar
Im running that exact 1/8 mile time and MPH and a 2.0 60' with the mods in my sig. Weird!
Ends up for me coming out to a 13.2 @106 for me. My track is 3100' above sea level though.
Old Aug 2, 2004 | 07:57 AM
it only dynod at 315hp and 325tq (at 5000rpm, that is one sign that my tranny is slipping) the car is set up to shift at 6200 or 6300.
Old Aug 2, 2004 | 09:19 AM
speed_demon24's Avatar
Seems slow to me, My best 1/8th is 8.356@84.45mph with a 1.917 60'. Mods in sig. My best 1/8th trap is 85.6mph, so your times are definatly off. I would get your tranny fixed then run it again.
DirtyDaveW
Dec 1, 2016 05:37 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
Fastbird93
Jun 3, 2015 05:56 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
