Has anyone actually passed emissions with EGR/AIR/rear o2's deleted?
Old Aug 2, 2004 | 02:26 AM
pillagenburn's Avatar
has anyone actually passed emissions (in an emissions-**** state) with EGR, AIR, and rear o2 sensors deleted? If so who did your tuning?
thanks
Old Aug 2, 2004 | 03:07 AM
RE AND CHERYL's Avatar
Re: Has anyone actually passed emissions with EGR/AIR/rear o2's deleted?
You would have to have a real mild cam to pass with the air and EGR removed. I personally see no reason to remove them since they don't effect power.
How does your state test OBD II cars? Delaware connects their computer to the diagnostic port of OBD II cars to check the system. If you have disabled or removed these items, you will fail. You have a better chance if they test emissions at the tail pipe, but it would be tough.
Old Aug 2, 2004 | 08:02 AM
91RSLT1's Avatar
I passed without my air pump and EGR. I also have a very mild cam like RE AND CHERYL said, however it was untuned and had NO problems. Chances are your car will be scanned because your car has OBD-II. This is also the way that MO. test OBD-II.
Old Aug 2, 2004 | 09:21 AM
ok, they do the plug-in test in my state
they test to see if the PCM is throwing any 'readiness' codes. I've got my air pump and EGR removed. If i can just get the two rear o2 sensors to post as 'ready' then i'll be OK. I do have o2 simulators but apparently those do not work
any other ideas? thanks
David Dempsey
Mar 12, 2016 12:42 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
Cam's maro
Aug 11, 2015 07:45 AM
tnmotown
Aug 10, 2015 11:52 PM
